I've been looking around for a good deal on a CMI8788-based sound card to replace my X-Fi since it won't work under Linux. I don't have a lot of money to spend, ~$100, and one of the cheaper CMI8788 cards like the BGears B-Enspirer or the Sondigo Inferno seemed to be my best options. Hell, I'd love to have a Xonar D2 or an HT Omega Claro, but they're just too expensive.
Anyhow, I've been doing a lot of comparisons between the 8788 cards out there and I've learned a lot about them - for example, that the B-Enspirer and Inferno appear to use the same reference design. A quick look under the hood of Razer's AC-1 revealed that it appears to be a modified version of the reference model. The opamps, DACs, etc are the same as the Inferno and B-Enspirer, but the layout is different. Most importantly, it appears to have a FRONT PANEL AUDIO connector! Huzzah!
With Razer being Razer, I never dreamed that I'd see the AC-1 anywhere near my price range, but I've found it being sold new for $92 shipped, which is less than what the B-Enspirer is currently going for on Newegg. It just might be the option I'm looking for: a hundred bones or under, CMI8788 with decent components like the Enspirer and Inferno, and a front panel audio connector. The keyword here is "might"...how would it stack up to the reference design cards? Would having that adapter on the front adversely affect the sound, since I won't be using the Razer headset? Is this too good to be true?
