dpoverlord
- Nov 18, 2004
making a new build! TOtally want a ratpad or 2 or 3!~
Business plan is still in the making.making a new build! TOtally want a ratpad or 2 or 3!~
My sample from the test batch is working well.Business plan is still in the making.
I am going to be reaching back out soon to dig down on specifics of your experience. I already have a list of changes to be made.My sample from the test batch is working well.![]()
or 5 or 6making a new build! TOtally want a ratpad or 2 or 3!~
Honestly after my old xt started having spots where the texture is worn down where the mouse hangs a bit I switched to a giant soft cloth desk pad and I kinda like it more then the xt. My wrist hasn't felt better in a decade form the bit of padding.or 5 or 6![]()
I prefer the XT for the tracking it provides on the mouse that i use.Honestly after my old xt started having spots where the texture is worn down where the mouse hangs a bit I switched to a giant soft cloth desk pad and I kinda like it more then the xt. My wrist hasn't felt better in a decade form the bit of padding.
Not yet still waiting on production. You can follow the twitter profile for the pad here: https://x.com/RatPadzOG?s=20are there any updates to this?
You need to hurry up my og xt was jacked by a bitch and used for a rolling tray and when I I got it back it was fuckedWe have now talked to everyone that has a RatPadzOG for testing. Been about 9 months now. There are some changes that are going to have to be made as I am not happy with the product for long term usage. I want to look into changing the surface material, thickness, feet, and some machining issues. Getting some excellent feedback from our [H]ard Judges.
Hopefully you guys are using the same texture style as the XT. I like that the pad is now a rectangle and flat so that it doesn't convex like all of mine did hahaWe have now talked to everyone that has a RatPadzOG for testing. Been about 9 months now. There are some changes that are going to have to be made as I am not happy with the product for long term usage. I want to look into changing the surface material, thickness, feet, and some machining issues. Getting some excellent feedback from our [H]ard Judges.
