notarat
- Mar 28, 2010
Prefece: Still working on my setup so this is an incomplete "review". Will update as changes occur.
I received my Raspberry Pi earlier this week and here are my initial impressions.
It doesn't look like much when you first remove it from the packaging. That's mainly due to the board lay-out, which is clean and barren of any non-essential items. As is sometimes the case, however, looks can be deceiving.
The following ports are available:
HDMI (Sound over HDMI is enabled)
Ethernet (10/100)
2x USB 2.0
Composite video
Analog Audio
I hopped online and grabbed the latest stable build of Raspbian and burned the image to an SD Card. then I assembled the various bits, gathered and connected the appropriate cables, and powered up the unit for the first time.
Boot Times
Raspbian - It was nothing to write home about, but it was by no means so slow as to elicit complaints. It boots faster than my phone so I find its performance in this area completely acceptable. Offers the user the ability to configure several different aspects of the system's operation on the first boot. This is a nice touch. Since this is not a review of the OS, let's just skip to the next OS
Arch Linux - Noticeably faster boot time. Boots to the command line like Raspbian but, unlike Raspbian, does not give you the option to boot to X upon startup.
XBMC - Interesting OS. When you download the XBMC image, it is not the final image. You burn the image to SD Card and, once the RPi boots up, it downloads the rest of the needed code and builds the OS.
Problems Encountered
1 - Networking -- Network initially kept dropping out due to the USB issue mentioned on the forums. Remember, the Ethernet connection is a USB to Ethernet implementation so a saturated USB Bus affects Networking. Resolved by using fewer USB devices (Bluetooth Keyboard/Remote/Mouse Combination unit versus Keyboard, Mouse, Media Center Remote)
2 - Internet Connectivity -- Once Networking was corrected, I could not access the internet. Okay...this should be simple. I just need to add my RPi's MAC Address to the MAC Filtering Table on my DGL-4100, right? Nope. I was never able to resolve the issue. The RPi and D-Link had no interest in peacefully coexisting. No matter what settings I changed, the RPi and D-Link DGL-4100 would not communicate and establish a connection. Bypassing the Router fixed the internet connectivity issue immediately.
3 - Choice -- With three now-working Distros to choose from, I found myself waffling. I'd work in 1 distro for 20 minutes then hop over to one of the others...
Performance
Performance-wise, the unit is totally acceptable. I've seen its performance described as "...like a P2-300 with awesome graphics". I'd say that's a pretty accurate description. I noticed lag here and there, but it is acceptable to me. Performance when viewing HD video is superb. At least as good as watching Cable HDTV. Sound over HDMI is enabled by default and it "just works", at least in Raspbian and XBMC. I did not get far enough in ArchLinux to see if it worked properly.
Pics
Remote/Keyboard
http://img43.imageshack.us/img43/4995/remoten.jpg
http://img690.imageshack.us/img690/6302/asuskeyboardremote.jpg
Raspberry Pi
http://img36.imageshack.us/img36/3926/45215137.jpg
XBMC
http://img17.imageshack.us/img17/5104/img0057gh.jpg
http://img14.imageshack.us/img14/1078/img0040ji.jpg
http://img820.imageshack.us/img820/4527/img0038cr.jpg
Ethernet (10/100)
2x USB 2.0
Composite video
Analog Audio
Boot Times
Performance
Pics
Remote/Keyboard
Raspberry Pi
XBMC
