Mc Masta Hompus
- Aug 2, 2012
Hey, i currently have 1 samsung 830 128gb ssd, and i was wondering if i could get another one and raid 0 them without formatting?
You should not do raid 0. I don't think you're aware of how bad it is.
Moving the files over is easy.
no redundancy...
Not an issue if you get out of the mindset that "RAID is backup"
No. You will have to reformat.
No you don't have to. I have made the switch from RAID to single disk and back again just by making 2 registry changes and ensuring the drivers for each configuration are installed.
1. Redundancy isn't even a point of discussion with RAID0... 0 is for performance.
2. The whole 'doubling your chance of failure' idea is largely crap with SSDs since an SSD is nothing but several banks of NAND in a striped set anyway.
My fucking god it seems like the [H] is turning into a bunch of panzies the last few years.
But to answer the OP's question:
No, with RAID0 you will have to create a new striped array and that's destructive by nature.
Yes, you could potentially make an image of your current single drive and then restore it to the RAID0 you will create after the fact, but there could be issues with getting the restored partition on the RAID0 array aligned properly for maximum performance (the partition start offset needs to be 1024KB or multiples thereof).
My advice would be to start fresh with a new install of your operating system to avoid these issues.
You should also be aware that TRIM will only work in a RAID array if you are using a motherboard with a Z77 chipset. Without TRIM being passed to the drives in the array you would see a (very) gradual loss of write performance from the array. Since your signature indicates you are using a Z77 based motherboard this shouldn't be a problem. You're gold.
Go for it and enjoy your SSDs in RAID0!
Well said.
Get those SSDs in RAID 0 and reap the performance benefit. I run two SanDisk Extreme's in Raid0 without TRIM. By the time the drives decay enough for me to notice it will be time for newer faster drives.
Live fast and Die [H]ard!
I bet you did not go from a single SSD to a 2 SSD raid 0 by this method. Unless I am understanding the question wrong.
or just re do it.
I vote Raid 0 as well, you'll get to say first all day.
raid 0 with SSDs is retarded.
what is the point? raid0 used to be useful when the disks were a bottleneck. a sata6 SSD is not a bottleneck for 99.999% of desktop workloads.
if the ssd isn't the bottleneck the only thing you gain via raid0 is a larger volume but that can be accomplished via concatenation or mounting directly to a folder.
oh and twice the chance to lose your data forcing you to waste time recovering from backup.
raid0 with ssds is retarded benchmark epenis measuring. nothing more.
Can you explain
lol, yeah, i have no idea what i'm talking about ... carry on with your stupid setups where you realize zero benefit.
Zero benefit from a raid 0 compared to a single SSD? Wow.. Someone needs to go look at benchmarking or see it for themselves LOL.
I have two Kingston HyperX 240gb in Raid 0... blazing fast 1kGbp/s read/write. wouldn't go back. Love it too much
Have a pair of the 120gb's in Raid0 and wouldn't it do it any other way. Went with the HyperX because not only were they a killer deal, but heard they run like hell in Raid.
can you post you as ssd and crystal benchmarks please.
Will do, but won't be home until tues for my Far Cry 3 release party
I was under the impression that the x79 Sandy Bridge-E Intel Controllers supported TRIM with the new software as well? I was just going to try RAID0 with 2 Agility4s i got on black friday with the Rampage IV extreme.
raid 0 support is z77 only (officially). i think intel has plans to add support for x79.
The rewards out weight "negative"
I get ~500mb/s read while he gets ~980mb/s read. It is fast and awesome.
