programatix
- Dec 17, 2014
That doesn't make any sense... that position is too low for a checkbox. Do you have your titlebars set larger than normal?
In any case, here's an adjusted test version with the coordinates you gave me for the checkbox, lets see if this works for you: https://db.tt/AkpjeXzF
Hi, the script works.
On the position, the following is the screenshot. The titlebar is the default size. Well, everything is in default size. I had the mouse cursor inside the checkbox at Samsung.
