Quick question about fan placement.
Syribo
Can you put fans flat down on the bottom of your case? Would this even be beneficial, since it wouldn't really have a vent to be able to do any kind of intake, or even exhaust outside the case. I'm just wondering if you could put one or two on the bottom, and if it would help, as they would be blowing up at the video cards?
Or, is this not smart? Just wondering :) Trying to figure out where to put a bunch of my extra fans I have.
Laying the fans down on the bottom of the case with no intake ports won't do anything besides add more noise to the PC. So no point in doing so.
bah, just make some holes on the bottom of the case. ;)
How many extra fans do you have?
You want to set up a draft circuit so you have some fans pulling in air ,while others are pulling out air.
