The coolant is good for the life of the warranty.
1. Buy large 12" copper pipe about the width of the CPU socket and weld a flat plate with screw holes on the other end. Make sure it's flat and polish until flat and shiny. Test apply to motherboard and check that thermal material has left a nice even imprint, if not adjust pipe to compensate, repeat until perfect. Or buy a readymade one.
2. Now get a bunch of vaseline/dragon skin/eraser and coat motherboard/socket everything. Tear up motherboard/CPU warranty.
3. buy lots of liquid helium from where you can buy it from. Put copper tube in freezer.
4. Place cold tube on motherboard and use negative ℃ appropriate TIM. Turn off overvoltage protection/safety on motherboard.
5. Fill tube with Liquid and turn on. Hope there is no cold bug.
6. Refill every few seconds (might want an assisant to do this) until computer is off. Stick V over 9000 and dial the multiplier. Possibly replace CPU every few weeks from hot/cold thermal stress.![]()
I'm thinking I will just keep my computer in Antarctica, and then remote desktop to it.
Ooo, that sounds a bit pricey. I can afford the liquid helium, but the servants that go with it, and the extra parts, may outpace my budget. I may have to rethink things. Perhaps nitrogen may be a better fit? It should use less slaves at least.Please correct me if I'm wrong.
