Question about motherboard built in RAID controller - completely lost....
wasserkool
So I am trying to configure two Intel 510 SSDs in RAID 0 on my gigabyte 990fxa-ud7 motherboard that has the AMD SB950 chipset.
There are altogether 6 SATA 6.0 gbps ports on the motherboard that is controlled by the AMD chipset. But the motherboard will fail to book if I enable RAID with the following setup:
P = Port
p1 - Intel SSD
p2 - Intel SSD
p3
p4 OCZ MaxIOPS - My windows Boot drive.
p5
p6
I am guessing the built in chipset RAID functionality does not allow you to mix and match drives? Does it mean that if I want to run RAID 0 off the AMD chipset the remaining port must be unused?
In my experience I've never had this issue. I currently have 3 128GB Kingston SSDs in RAID 0 and a Corsair 256 GB SSD all alone (still running in RAID mode). Granted this is on an Intel chipset, however I have RAID arrays on other AMD based systems, not with SSDs, but with different drives some in RAID 0 and the other in RAID 1. Not sure what the problem is. Silly question, I know, but are you sure that your boot order is correct since switching to RAID mod? Or is the motherboard simply not posting?
did you select raid mode in the bios before you installed the os?
I just went through this on an X58...there is a workaround registry edit, but I chose to reinstall windows
Thanks for the suggestion but in my case the OS is on a non RAID drive which is the single OCZ Vertex 3 SSD. I just want to setup an RAID 0 array with the two intel drives as an application drive in the OS.
The motherboard simply does not post and I cannot even get to the BIOS if I enable RAID functionality on the chipset controllers. I am thinking once RAID is enabled on the chipset all six ports must be filled with the same drives?
AMD's and Intel's RAID setup are completely different.
Performance wise AMD is clearly inferior to Intel but you hafta work with what ya have. :)
I suggest you read this AMD RAID set-up guide and go from there.
Don't bother with the RAIDXpert stuff but the first 10 pages will give you the instructions you need.
Good Luck!
Good Luck!
Thanks again for the help - I've read the linked manual but it primarily talks about installing the OS on the RAIDed drive which is not applicable to my situation.
I did some more tinkering by removing all other SATA drives from the SB950 ports and just left the two Intel SSDs on port 0 and 1, went to the bios to enable the RAID functionality and BAM....the motherboard refuse to post and spits out some garbled message. I have to reset the CMOS everytime I do this......I am so lost lol...
Everything works fine and dandy if I leave the SATA setting as AHCI mode though. I've also installed the RAIDXpert software and logged into the admin page but it is not detecting any of the drives plugged into the system..
Did you read the part about excluding drives from the array?
All the info you need is in that link.
Keep in mind that to put a drive into an array it will loose all of it's previous info.
Hopefully someone else can help you along.
Good Luck!
Good Luck!
I did..but the thing is once RAID is enabled in BIOS, the mobo will fail to post and give the following error:
"What? 40:0eh <> 40:13h?"
I understand that Intel and AMD are different in terms of performance, etc. But his BIOS should still POST with RAID enabled. I would try updating or re flashing your BIOS. Otherwise, honestly, sounds like you have a bad board to me.
I just figured out...I have an LSI SAS Adapter plugged into one of the PCIE slots that requires a ROM to load in order to initialize the array. I think the adapter is taking up the available memory to load the ROM and leaves no additional memory for the AMD SATA RAID ROM to initialize. I found out by unplugging the SAS Adapter as the error message is also gone...
Interesting find nevertheless.
I know that other motherboard refuses to post at all with any SAS controller installed because it lacks the memory needed to load the controller BIOS for it to initialize.
So yeah..its very interesting.
Now you're making headway!
I've run into this problem before when the BIOS couldn't handle the extra memory needed to run two different arrays.
