- Jan 18, 2003
Why is it called GDDR5 when it seems to me that it is really GQDR1 (quad-data-rate)?
Because it's the 5th JEDEC version of DDR.Why is it called GDDR5
You were misinformed if you read that it is quad data rate, but I had also seen that (wrongly) implied in a couple of reviews.SAMSUNG GDDR5 is a hyper-synchronous, double data rate DRAM, operating at data clock speeds up to 2.5GHz and delivering data at speeds up to 5.0Gb/second.
Because it's the 5th JEDEC version of DDR.DDR stands for Double Data Rate, which it still is.
From the Samsung product page:You were misinformed if you read that it is quad data rate, but I had also seen that (wrongly) implied in a couple of reviews.
The HD 4870 has GDDR5 memory at 1.8GHz DDR (3.6GHz effective), which gives 3.6GHz x 256-bit x 1 byte/8 bits = 115.2GB/s bandwidth
For $299 you get a video card that is clocked at 750MHz core, 900MHz memory but using GDDR5 so the memory frequency is double that of double data rate, so it would be 3.6GHz. At 3.6GHz this gives you a memory bandwidth of 115GB/sec.
coulda sworn it was 900x2x2![]()
I didn't want to name names.this is from the H review
Here's a data sheet if you still don't believe it: http://www.qimonda.com/download.jsp?ref =/qis_docs/Datasheets/Datasheets%20Graphics/IDGV1G-05A1F1C_rev060_www.pdf (remove the space since ref = is blocked here) Samsung's data sheet isn't available yet or I would link that one too.coulda sworn it was 900x2x2![]()
The GDDR5 SGRAM uses a 8n prefetch architecture and DDR interface to achieve high-speed operation. It can be configured to operate in x32 mode or x16 (clamshell) mode. The mode is detected during device initialization. The GDDR5 interface transfers two 32 bit wide data words per WCK clock cycle to/from the I/O pins
No.It is effectively QDR, but still not. Each lane delivers 2 b/clock whereas previous techs only do 1.
But it's not 900MHz memory.
It would be like describing HyperTransport 2.0 in S939/AM2 processors as a 200MHz bus. That is only the input clock speed, which is multiplied on the CPU 5x (default) and uses double data rate links. The HTT bus speed is always written as 1GHz DDR (1000MHz DDR) or 2GHz (2000MHz), not some convoluted description that takes the internal multiplier and reference clock speed as the link speed (unless to illustrate how the link speed is generated).
Naw, I just wanted to clarify that 900MHz wasn't the memory speed since the [h] review quote was posted twice. Since it was repeated in other reviews, I wonder if it was in the AMD documentation or just cribbed.im not sure if you're still arguing with me
Naw, I just wanted to clarify that 900MHz wasn't the memory speed since the [h] review quote was posted twice. Since it was repeated in other reviews, I wonder if it was in the AMD documentation or just cribbed.![]()
its been listed at 900mhz EVERYWHERE. even the overclocked and unlocked version mention that they will allow up to 1100mhz for 4400mhz effective. . so is the whole world wrong or just you? surely someone else would have noticedNaw, I just wanted to clarify that 900MHz wasn't the memory speed since the [h] review quote was posted twice. Since it was repeated in other reviews, I wonder if it was in the AMD documentation or just cribbed.![]()
its been listed at 900mhz EVERYWHERE. even the overclocked and unlocked version mention that they will allow up to 1100mhz for 4400mhz effective. . so is the whole world wrong or just you? surely someone else would have noticed![]()
I think the confusion comes from the input clock (Fck) running at 1/2 the memory clock rate, meaning it's doubled internally before being used at the external data bus/clock signals (Wck). But GDDR5 is still double data rate since it only does 2 transfers per clock. And it is odd to specify the clock as 900x2x2 since the memory interface runs at 1800MHz DDR on the HD 4870. The input clock does not run at 900x2x2.And yes, the external memory interface does run at 1800MHz DDR.
my point was that NOBODY else has mentioned this when reviewing the cards. so is every tech website really that clueless?He explains why the clocks are listed that way right here:
Please come back when you have improved your reading comprehension, KTHXBYE.
