if one has a Q9550 on a Rampage Formula x48 with 4 Gigs of DDR2 ...is it really worth it going with an i5 or an i7 ...?
don't let fanatism answer for you...please advice if there is a real difference a noticable difference. thanks !
I have Q9550, what the best settings to 3.4-3.6?Yeah the Q9550 is a beast of a chip. Throw a nice cooling system on it and ramp it up to 3.4-3.6.
I had a P2 940 o/c to 3.7ghz (which is around the same speed as a Q9550)
And I upgraded to an I7 920.
It is night and day how much faster then I7 920 is stock (let alone overclocked).
I7 > all
i also have a Ph II X4 955 and the i7 is NOT "much faster" in gaming - either at stock or at Max OC.
Uhhh yes it is
Trying playing at 1920X1200 and above, you will notice a difference.
And I had my p2 @ 3.7ghz.
You are dreaming. i have also tested Athlon X2 350, Ph II 550 X2, 720 X3 and 955 X4 with GTX 280, HD4870-X2 and 4870 Tri-Fire CF-X3
i benchmark my games at 19x12 with maxed out details and 4xAA/16XAF and i have the proof
there is almost no difference at high resolutions; sometimes i7 is slower, clock for clock than either Ph II or Penryn
Now if you drop the resolution below 14x9 and lower details, the core i7 will pull away from the crowd
I am not dreaming. I just sold my P2 940 build which had the best overclocking motherboard with 4gigs of ram bro.
Its night and day. Once you get an I7 920, then you can comment on which is faster. Otherwise you have no idea how fast an I7 920 is compared to an overclocked 955.
Stop being a fanboi bro....seriously....And this is coming from a LONG TIME AMD buyer.
P.S. The reason you dont see a difference is because you are Video card limited . Get a new video card
Ridiculous. How is HD 4870 TriFire - 4870-X2 + 4870 in CF-X3 - limiting anything? Only 5870 CF or Tri-SLi is faster.
i have my i7 920 clocked to 3.8 GHz - effectively 3.97 GHz - and i have TESTED them - extensively - against e8600, Athlon II 250 X2, Ph II 550 X2, 720 X3 and 955 X4
- and i have published the results and my latest article goes up this weekend.
what testing have you done besides "feelings" ?
Don't call me an AMD fanboi
--i AM proudly an Intel fan; my first AMD rig was last year - and *in hi-res gaming* i7 is NOT faster than Ph II nor Penryn - at either 1) Clock for clock - or 2) Overclocked to the Max
Then your evaluation is wrong. Even hardocp proved it bro.
Quote:
Link please to i7 beating Ph II or Penryn in high res gaming - if you can
- make sure they are compared clock for clock and also overclocked
- make sure the details are maxed out with 4xAA/16AF in DX10 and fast graphics is used
-- and don't just pick one game
And you called him a fanboy?
http://hardforum.com/showthread.php?t=1420299
i7 is more powerful in high res gaming if [H] testing is anything to go by but it's definitely not a night-and-day difference.
Well, we are now comparing CPUs based on changing the setting of the Graphics to see "highest playable settings". So much is depending on the videocard.
What i asked for was Graphics at the same settings - only changing the CPUs
- and you will see much much closer results.
Even with the benches linked to, there is not much difference between i7, Penryn and Ph II - once they all get around 3.5 GHz; that is something that HardOCP also concluded.
The biggest visual difference will always be the graphics card - not the CPU (as long as it is capable)
It doesn't really matter if graphics are at the same settings in the [H] test. The logical conclusion is that if the i7 performs better than X CPU at the same clocks despite the fact that it's using higher graphics settings, then that lead will only widen if you test the i7 at the same graphics settings, though not by enough that anyone using a fast quad should be looking to upgrade their processor, in my opinion.
I do agree with you though that the other guy is dreaming. There are very few cases in gaming where upgrading from a Phenom II 940 @ 3.7 is going to show a night-and-day difference. Hyperbole doesn't help anyone.
its getting to the point tho where a fast dual core is not gonna cut the mustard. we are seeing games now that use multiple cores.
OK, maybe there are 5 or 6 games where quads really make a performance difference over dual coreand a whole bunch better, too.
I remember the flak Ironclad drew when they make SoaSE such a huge game, yet it only really used one core. The second core was for 'texture work' which was to say (without modding), not much at all.
But then you have SupCom, WiC, and others (sorry, out of the loop here) that do leverage multicore to it's best.
i mainly run FSX on a stock E8400, with regards to OP question, would i notice a difference if i put in a q9550 or start over with an i7 set up?
Flight Simulator is very CPU intensive. You might notice a difference if you *overclocked* your e8400. Try it, it costs you nothing (if you are even reasonably careful).
What is the rest of your system like (esp. the video card)?
How much better is the 9550 over a 9450 (which is what I got)?
It is safe as long as you do not increase the voltage and watch your temps.i have gigabyte EP45-DS3LR
e8400
4gb ram
512 ATI HD4850
250gb hdd
it's not that i don't want to overclock, it's that i'm not 100% how to do it =/, especially given my mobo, read some reviews on newegg and it's not that great for OC =/
Brent Justice said:It is clear that multi-core CPUs aren’t of paramount importance to gaming just quite yet. Only in GTA4 are we possibly seeing a difference. It really is clock speed that matters the most. This isn’t to say that quad core CPUs aren’t useful for other things, but for gaming, clock speed is where it is at to achieve the best enjoyment from gaming, and to get the most out of your video card.
Though the framerates were higher, we were not able to increase graphics or in-game settings, and the performance was smooth enough already on the QX9650 that the extra frames supplied by the Core i7 did not give us a better gaming experience. Technically the Core i7 920 is faster than Core 2 Quad in games, but the resulting performance wasn’t enough in these games to allow a better gameplay experience; mostly we were still GPU limited.
