Intel Q9450
Lian Li PC-B25B Case
OCZ Vendetta 2 HS (OCZ Freeze TIM)
Real Temp 2.5
Idle at 2003.8 Mhz
VID = 1.15
Ambient Temp = 22.78C (Approx. 73F)
TjMax 95 = 40C across all cores
TjMax 85 = 29C across all cores
I set my TjMax to 85 in Realtemp and my temperatures seem to be in line now. I am at 29C accross all cores on my Q9450 (computer is idle and running at a reduced speed of 2003.8 Mhz). These temps seem correct for this processor and reduced Mhz.
With TjMax set at 95 I was running at 40C across all cores with the computer idle at 2003.8Mhz. This seems too high especially when I am using one of the best air coolers (OCZ Vendetta 2), 45nm processor, HS is properly seated, and the Mhz is reduced.
Let me know what you think!!!
Real Temp 2.5
Idle at 2003.8 Mhz
VID = 1.15
