Right now I am just running my Hyper 212+ with a fan in push. I have an extra fan that I want to use on the heatsink also. I don't want to run them both at full speed all the time and would like to leave the stock one hooked up to the 4 pin header and the other is a 3 pin. Would it be better to put the 4pin one in push or pull? Or would it be better to just leave the 2nd one off since they would be mismatched? Also, am I correct that if I put a 3pin on the 4 pin header it will just run at fullspeed all the time?
