ZIPPER978 said:Hi im looking into getting PC-E in the future and was wondering what is the best PSU i could get for a socket 939 motherboard.
ZIPPER978 said:ok cuz everyone wants to know specs it will be a
ASUS A8N-SLI Deluxe Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard,
eVGA 256-P2-N529-AX Geforce 7800GTX 256MB 256-bit GDDR3 PCI Express x16 Video Card,
OCZ Platinum Series 2gb184-Pin DDR SDRAM Unbuffered DDR 400,
AMD Athlon 64 3800+ Venice 1GHz FSB 512KB L2 Cache Socket 939 Processor.
hows that for specific.
ZIPPER978 said:i would say my budget for a psu would be around $80 or so.
Spectre said:we need to know a lot more about the setup than that.
ZIPPER978 said:i already took a survey and entered all the correct items and it said it would be around 400watts so next time read the entire forum.
ZIPPER978 said:well what survey can i take that will tell me what i need then?
Spectre said:Edit: Oh and don't quote me out of order. The comment you quoted in your reply was posted before the calculator was.
Spectre said:Well I gave you the takaman link above but here it is again: http://takaman.jp/D/index.html?english
It can be a little daunting especially since you have to add the values for the 7800 by hand. Had you given me a complete list I was going to do the leg work for you. For your purposes the 6800 Ultra data is close enough to the 7800 to use in this capacity. http://www.xbitlabs.com/misc/picture/?src=/images/video/ati-vs-nv-power/6800u_table-b.gif&1=1
ZIPPER978 said:oh yes and in the future i am planning to run sli
renegade44e said:If you use this link you don't have to add anything. In fact it will even account for oveclocking your cpu
http://www.extreme.outervision.com/index.jsp
renegade44e said:he didn't quote you out of order He used a different calculator I POSTED which is much more up to date that Takamans.
Please read thruogh the whole thread next time.
nas82 said:He did quote him out of order, he quoted spectre from his first post in this thread, and then zipper tried to insult him by saying, "try reading the whole thread" by quoting him way down in the thread after it was already said and done.
Zipper, if you would try and be more forth coming and less thickheaded in your response, you MIGHT actually get a decent answer to your question.
Edit: PM sentrenegade44e said:he didn't quote you out of order He used a different calculator I POSTED which is much more up to date that Takamans.
ZIPPER978 said:funny i took it again and this time it said i needed 518, i think i might have forgoteen to add the sli first time
The DFI N4 mobo's seem to be doing best with the following.Spectre said:Well without knowing the entire setup (ie just the mobo, cpu, ram and videocards) it is going to have a worst case 12v draw of 17amps. Personally my recommendation would be a Seasonic S12 since you aren't using a DFI board...either the 500w or the 600w.
ASUS A8N-SLI Deluxe Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard,davidhammock200 said:The DFI N4 mobo's seem to be doing best with the following.
