Nice work!
You should have purchased my phase unit and saved some money.... But mines not cheap, holds my quad at -41c loaded.....
Vapos can't hold a high load for long, it will burn them up.
I ordered some sleeving kits and a new A.C. Ryan UV Reactive side window (which needs to be cut to fit). After buying the sleeving kits, I realized that I need to buy a heat gun.
I started on sleeving the exposed wires on the power supply and man, what a P.I.T.A !
