Thanks man, we appreciate your buisness and the compliments.Bump for some excellent work! Just ordered the 80mm versions of the Evil Joker and Pentacle.
The pentacle you will be recieving is a new thicker mounting ring version. We are beefing up all the old 80mm designs so they are tougher and are much higher off their mounting surface. All that = cool.
We used to use sculpey for the grills, but it is too brittle and they damage easily. Now I use a homemade compound that air dries and does not require heat to cure it. It is much tougher, nay indestructable. The very earliest designs like the penatcle demon grill was actually carved out of auto body filler, talk about time consuming!!!what are those things scuplted out of? I need some material ideas for a case mod that I'm doing. I'm leaning toward sculpy for myself, but thought these were extremely well done with whatever it is that they are.
