perhaps some "quality" blackberry videos of the router in action coming soon =)
but one question, wouldnt carbon fibre will amplify the noise inside the case?
Teaser:
A little taste of the EMI shielding I mentioned before.
These are the left-over bits from the radio/instrumental shielding on the US presidential helicopter. They will be used to shield my portable amp, and my sound-card.
Sidewinders said:Four new Revision C models from Delta's AFB line have arrived!
The AFB1212GHE Revision C Grand High Speed is our newest king of 120mm fans. This dc fan motor provides over 240 cubic feet of air out of a traditional design that has been highly refined and tuned by Delta's fan motor team. Comparisons with our other high end Delta parts show it has modest power requirements for its ability to move so much air out of the standard 120x38 millimeter form factor. It does lack the directional blades which we've all come to know as Delta's patented design, which helps airflow move more consistently straight out of the fan housing. However, as noted in its lower decibel rating, it will also lack the high pitched whine that accompanies directional fin fans. The AFB parts can be undervolted slightly more, but apparently cannot be overvolted as much. For power users adjusting the voltages on these parts, it will be a welcome change.
