dondan
- Apr 15, 2013
I thought that the psu goes off if the card pulls more power than the psu could provide.
Hi, I saw your thread first at OCN so posted a question there, to which you have already answered on OCN and thank you for your reply. Here is the exchange we had:
Assuming you haven't done a custom PCB work yet, it looks like you are already operating Q87T with GTX970 with two independent 12V sources into GTX970 without frying anything.
This "180W" is exactly what you are measuring? The power consumption of the entire system or the whole GPU or just the power fed through the PCIe 8pin PEG? If the entire system, then is that the AC measurement on the wall?
Also, if I understand your answer correctly, power is constantly fed to the GPU whether the power to the motherboard is on or off. I don't think that's what people like to have, hence dondan's question on how you're planning to let the power-on of the Thin Mini-ITX trigger the 12V input to the GPU. I was thinking you're going to provide a relay.
Another thing I have been wondering and I believe I have asked this question in dondan's A4 thread when we talked about a Thin Mini-ITX and high-end GPU combo, but I still don't know the answer (yes it's probably a dumb question but I'm clueless on this): when the GPU is being asked to do the kind of task that would draw, say, 50W from the mobo thru a PCIe x16 socket, how does it work if it is actually connected via PCIe x1/x4/x8 that is set to 25W max? Is it designed so that whatever the extra amount is required over 25W will be drawn from the PEG connector, or will the GPU simply try to cope with the task with less power and throttle down?
Yes I'm interested in this. (Interested in QinX's and dondan's solutions as well.) When you said a 60mm riser, did you mean a 60mm long flex riser or a rigid left-angle (left when looking from the rear ports) riser that is 60mm tall from the top surface of the mobo? In the latter case it seems a bit too tall to achieve an USFF size.
As i maybe told, i have a thread in a german forum where i shared the idea of an 3L thin itx system for about 7 month. But not for doing it be my own, only share how it could be possible and the hope that somebody else will do it. And somebody in germany actually do it. He said, that the PCIe gives 25W and the other remainig 50W will the card pull of the 6 pin or 8pin connector. So you dont need to inject it directly in the raiser.
By the way here is a picture how to sync hdplex and thin itx out of my thread:
http://abload.de/img/drawinghmcz4.jpg
(the picture is some month old so i don't remove the powercable to the riser)
You can also try to contact Larry from HDplex or Frank of Picoboxfactory to produce a DC board that converts 19-24v to 12v with 250W and only pcie plugs. Syncing could be done by a special cable between sata-power port and dcboard. Perfect would be a thin itx board that has already 8pin pcie out and 16x pcie port.
Keep in mind that Nvidia with the 9xx series has implemented something similar to Intel's FIVR, which means a 145w TDP does not translate directly to 145w of power consumption.
It's a gross simplification I think, but those cards could draw 250w of power for 1/2 of a second, and 40w for the other half of a second to average out at 145w of total heat to be dissipated for that second. I think it's a large part of why Maxwell cards have a lot of complaints about coil whine - the power regulators are switching many times, on the order of multiple times every few hundred nanoseconds? This switching could place a lot more load on the PSU since the consumption swings so wildly and quickly
Here we go, a source:
http://www.tomshardware.com/reviews/nvidia-geforce-gtx-980-970-maxwell,3941-11.html
"Even though the average power consumption is only 176 W, the GPU draws almost 300 W when it's necessary. Above that, the GPU slows down."
walking away from psu talk
How about something like this? No watercooling needed but some good ventilation would do.
Depending on front panel size and additional space needed for HDPlex it would grow few mm.
What do you think?
I believe PSUs all handle it differently.
The size is intriguing, but the ITX 970s will likely be louder and even more so at a small size, with little or no blocking or dampening and amplified by the fact it will probably be a lot closer to the user.
Such a small PC wouldn't be placed where a regular tower would be (beside table, under table) but somewhere accessible like on the table for easy disconnection and transport. I can see people using them between multiple locations with KVM set up already (as one example).
Even if you can make the case fans very quiet, the pump noise will almost 100% be louder than the case fans and audible at a low speed.
Now having said all that, you (OP) should still go ahead and fully realise this. That's how we have progress - if no one tries anything then we don't get anywhere.
One of my crazy ideas was how small you can make a PC with 2x 295x2. If I had money and time, it would make a fun project. Just in time for 4k 5" screens.
You could go with reverse configuration where motherboard faces bottom and that bottom would be made swiss cheese and only GPU would need small intake from the top.
- Too less space under the board.What do you think?
Yeah, again, I know that. It's just It would be good if you were to support card from the thin mITX itself without HDPlex PSU.
If standard was meant to support AIO with external PSU why couldn't they integrate something like hdplex into board and draw power from it to other things like the AIO screen.
If you look at it this way you'll notice that those AIO's will have its own power supplies and the board connector which is unused if I'm not wrong.
Sorry to tell you, but you are in fact wrong. The AIO barebones do come with their own powerbrick, but the exact dimensions of the 19V power connector on the I/O of the board are specified by intel and those powerbricks plug into the board directly.
The mobo does actually have transformers for 3.3V, 5V and 12V on it, and it does power the AIO display and backlight via special connectors, one is a LVDS 40pin micro-coax cable for the panel (namely the ACES-50204-40), and the other is a generic 4pin connector for the backlight.
It is also able to power all sorts of HDDs and SSDs, and interestingly enough, most boards I used came with a cable that had four 7pin SATA power connectors and one smaller one that only supplies 3.3V and is most commonly used on slim ODDs.
So it could actually be possible to ditch the HDPlex entirely and power the GPU through those.
To be honest, that is a pretty genius idea, and it might just work.
This video shows it quite well:
http://www.intel.com/content/www/us/en/hardware-developers/ecs-g24-aio-pc-integration.html
I'd imagine the transformers for 12V that are onboard don't pack the juice needed to power 200W+ of graphics card.
It's draw will momentarily (for a handful of milliseconds) peak at much higher, but it;s average power draw is closer to 150-170W.
Unless the PSU's power protection circuitry has been set up with a very sensitive current-draw shutoff trigger (and has it placed AFTER the output smoothing stage), it won't be an issue. Remember how cheap 'n' nasty PSUs are rated by their peak load rather than their sustained load? A decent quality PSU will be rated for sustained load, but can provide a peak load significantly higher for very short periods.
Woah, where do you order a custom rad?
Small update:
1st I've ordered my PCBs, after inquiring with the manufacturer I've gone ahead and ordered them with a Nickel/Gold finish. It's a lot cheaper than having a hard gold, but the difference is that hard gold is meant for a lot of insertions, which shouldn't be the case with my build. Now I just pay 3 extra per PCB and don't have to worry about the copper oxidizing.
2nd I've also gone ahead and ordered a new external PSU. I've chosen an HP 350W brick that I like the design of. It should have enough power to deal with the GTX970 and everything else.
3rd
I've ordered my custom radiator, it should be build and shipped this week which is amazing!
and lastly 4th
I had an ASUS GTX970 mini for my build but as you guys have told me the reference GTX970 is just as short and even less tall. So i've asked the webshop that I bought my ASUS GTX970 at if I can swap it which they will.
All in a couple things in the works for next month.
Did you just order the PCB or will they solder the connector to it, too?
Also wow, that PSU is huuuuuge Yeah 350W will be enough, I'm running my 970 off a 300W PSU (though I'm using the i7-4770U, which only has 45W TDP).
A custom radiator is so rad
I think this was asked before, but is that a rad with included reservoir and pump?
So i've been looking into this psu deal. Dondan, QinX, do you think a Hdplex 160 would work instead of the 250 for the graphics card?
You didn't ask me, specifically, but if it powers just the GPU, it should work from my experience. I ran the 970 and the motherboard off of a 15A rail, so 180W.
Did you still get the same fps with the GTX970?
@iFreilicht
it is not a spam,
rrdiculous predication
I am trying to solve technical problem with implementation of mentioned GPU in my SFF case, details see above,
hope that somebody who bough already this card can take that measurement and help me to make decision to purchase or not Asus,
Thanks in advance
