iFreilicht
- Sep 23, 2014
I love the legs! I personally prefer the power but to to be on the front, but it's not looking bad without one, so just do it how it works best for you.
Would it be possible to change the thread title?
I just had an idea for the power:
Is the mainboards ATX19V connected directly to the DC-DC inlet? Because if that's the case, you don't need an additional inlet in the back of the case, you could just plug the PSU into the inlet of the board and connect the HDPlex PSU to the internal ATX19V header. Not necessary, but then you'd only have one inlet on the back instead of two, and you wouldn't need to split the cables internally.
I'm already doing that
dayum, dat cpu bottleneck tho...
What resolution were you running at? Mine is O/Cd now, but I remember a gain of ~12% from O/C so you can just subtract that from whatever results I can get tonight
Hey QinX, are you still using the Intel i7-4790 cpu as your finalized build? I ask this because in your benchmark results you stated using only an Intel celeron cpu. It would be interesting to see the gaming cpu and gpu temperatures for hour-long sessions. Keep up the good work and can't wait to see pictures of the finished build.
So HD-PLEX and the 350W Voodoo PSU work fine with this GPU. I do still have a whining noise coming from the HD-PLEX when at load so I will be swapping it with a new one that has better inductance and can handle the Maxwell peak power demands.
Hey, are you doing all of this on the thin itx board and the custom riser?
If this works out really well, it'll be interesting to see the thin-itx cases/builds become more popular. It probably will be a niche market, but I can see the potential. Keep up the good work, QinX.
It is normal, if the system pull more than 250W. I have the same situation with a GTX 780 which is not a Maxwell GPU.
How many watts can the HD-Plex powerboard pull when not actively cooled by fans? I remember dondan stating 350 watts or so when actively cooled.
Can you adjust voltage on the non-K i5/i7 cpus? If you can, I would suggest trying to undervolt the cpu as the stock settings are usually a bit higher than needed. If not, the K-edition cpus allow you to.
Just curious as to how your custom radiator is different from a commercial dual 80mm radiator like:
http://www.alphacool.com/popup_image.php/pID/1238/imgID/0
Huh, in my head I thought the GPU would be flipped the other way up (and at the other end of the board) so it and the CPU/mobo shared the same waterblock, using opposing faces.
Whoa
Was thinking the same thing. It could potentially reduce loop size but then you'd need a ribbon PCI-E extender with EMI shielding. The extender he's using should be a lot more reliable.
Other option is fab an extender that reverses the PCI-E pin out at the end of the extender. You could then just flip the card around. Your video output would face opposite of the MB I/O which may or may not be a bad thing.
I am itching to see how the cable management ends up on this thing
The temps of the PSU, SSD and other small components is also going to be interesting, they can only radiate heat out through the aluminium shell, as there is no airflow whatsoever in any areas but the radiator space.
I'm not very knowledgeable in terms of passive cooling, though. This may all be just fine.
That is the main unknown, I will be doing a lot of internal temperature readings when it is up and running. Perhaps even order a second top panel with some passive ventilation.
Let's say the 2x80 radiator isn't enough. What's your back up plan?
Could you simply adapt the case, make it longer for a custom 4x80 radiator?
The Passive ventilation would be just for allowing the hot air inside the case to escape and lower the internal temperatures. However I don't think it will be a real problem because there are plenty of fully passive cases that have the same problems of no cooling for VRM and PCH.
True, but those cases don't have all these hot components in such close proximity to each other.
The 2x80 radiator is enough for what it is cooling, GPU and CPU
I know
Also it's interesting to chat/speculate about it
Yeah, the most interesting discussions are the ones where nobody is an expert in the field, because you can speculate so much and there's no definitive right answer.
Have you seen the Streacom FC8 Fanless? It has DIY heatpipe things to turn its whole case frame into a CPU heatsink. From the reviews of the FC8 it seems an effective method: superior to natural convection. Perhaps this idea can work for you too?
