coolrunner84
- Sep 5, 2008
I followed on of the comments here and got the connector installed fine.
thanks, but it was me trying to be ingenious that caused my problems. (see my post above)
I think there are several norco models. The one I ended up getting doesn't have separate ports for SAS/SATA and all the cables plug into the right side (looking at it from the back). Here is a high res pic:
Also, I like my drives in read order (left to right top to bottom) so I suggest putting the cables in the opposite order it lists to. I ended up re-doing my cables since the two SF-8087 to 4 SATA cables I bought didn't work my areca and I fixed the order when I had to unhook all the sata cables and re-hook them.
PC Power and Cooling 750w is what im using to power my Norco
Does the Pc power and cooling have a ton of molex plugs?
Tyler
synctoy or robocopy
