Don't put it on the floor or you'll stub your toe on it.jayjaya29 said:Wow, its looking really nice now. It will be invisible in the dark.
flat4 said:Im thinking about going WC.im pretty sure u will have to leave the top bay empty, as it will go into some of it. as for the name it was something i thought of, i didnt even think about the tv show. as for the window on the mobo side it all depends how big of a window you go with.
XeRo_Dark said:I just ordered the same case ur working with and am waiting to recieve it.. As for you looking for a black mo-bo try soyo... That is if your goin with a A64, my friend recently got a soyo athlon 64 board, (Not sure of the exact model) and it works fukin awesome, its very stable and looks bad ass. Im waiting on my case to mod so i can finish building my new pc (the 1 thats in my profile minus the swiftech watercooling since i havnt found swiftech watercooling in a dececnt price).. I may do something of the same with the flat black on the inside, kuz if you were to go with a gloss it would reflect your Cold Cathodes and bounce all around looking somewhat tacky, plus gloss paint really attracts dust. But i may go with a midnight blue or just a flat grey or black on the inside, i havnt decided yet though. Your case looks great so far keep up the good work Happy modding
I'm the same way when it comes to the actual hardware. I just don't want to attempt to trust any other company. I'mm willing to shop around for non-hardware components though. My case is on it's way from excaliberpc and I'll get some sleeving eventually from svc.flat4 said:WC= watercooling. and as for the mobo, i think im going to go wioth the NF7-S2G, when ever it comes out. I always order my stuff from the egg, and always will.
Generally I'm the same, newegg all the way. I have used zipzoomfly with no troubles at all, prompt (cheap/free) shipping and well packaged (hard drive).Sobek said:I'm the same way when it comes to the actual hardware. I just don't want to attempt to trust any other company. I'mm willing to shop around for non-hardware components though. My case is on it's way from excaliberpc and I'll get some sleeving eventually from svc.
I'm in the same boat as flat4. You know, that boat where you are out of money and can't work on your project till you get more of it.
ati_azn said:do all newegg products come with a clock?
