DaCoOlNeSs
- Jun 8, 2004
that is completly BADASS. if I had the money I would pay you to do that for me
em00guy said:Here is the grill with the accessory door open It will be convenient there. I will replace the mic and headphone port with an Xbox controller port so I can use my Xbox controller on my pc.
Thats the plan. I just want to mount the port in the small door.ralfyboy said:i know i'm going WAY off topic, and really great modding idea btw, but you can buy an xbox usb controller adapter, and download XBCD drivers, and that way you can avoid all that trouble of putting an xbox port there. i got mine at www.liksang.com
just search xbox usb adapter and you should find it no problem. i got 2 of em, and it's great for emulators and sometimes FPS.
THE CASE LOOKS AWESOME! and i agree with putting those cones on the fans so it looks like jets n stuff..... (i dont know much about planes)
em00guy said:.:: IV. Power ::.
I’ve spent the last week attempting to find a solution to power those blowers. I wanted to power them to the 48v which made things difficult. I tried to find some power supplies on ebay but instead an interesting option arose. Under the recommendation of some smart people I’ve decided to build a pulse with modulator to vary the speed and power the whole mess with a modified transformer I fished out of a microwave. The microwave transformer was recommended because it is extremely heavy duty and can supply more amperage that I’d ever need. One problem though. I only need 48v, my microwave transformer supplied 2000v. So I found some instructions online on how to rewind a microwave transformer to supply lower voltages at higher amps. I’ll be removing the secondary winding and rewinding it with 13 gauge enameled magnet wire. Here are some pics.
The freshly liberated transformer on a text book for scale. This damn thing weighs at least 10 pounds.
http://www.thedigitalself.com/images/blu/DCP_1139.jpg
Removed the insulation paper from the secondary. The thick wire is the 120v primary the fine wire is the 2000v secondary. That’s what I have to remove.
[IMG]http://www.thedigitalself.com/images/blu/DCP_1142.jpg
Started at it with a hacksaw.
[IMG]http://www.thedigitalself.com/images/blu/DCP_1144.jpg
After 1 hour of sawing I made it through.
[IMG]http://www.thedigitalself.com/images/blu/DCP_1145.jpg
This is when I realized all that sawing was for nothing. I simply pulled out my jig saw and lopped the whole mess off.
[IMG]http://www.thedigitalself.com/images/blu/DCP_1146.jpg[/QUOTE]
if those blowers use brushless motors, though they probably don't given their size, i would rethink the PWM controller. they tend to make brushless motors hum like you wouldn't believe.
jkr266 said:if those blowers use brushless motors, though they probably don't given their size, i would rethink the PWM controller. they tend to make brushless motors hum like you wouldn't believe.
apHytHiaTe said:FRONT PAGE BABY!!! w00t! truly 1337
/spam
HiProfile said:Wow, didn't think those things could run on such a small circuit - the other guy with those blowers originally (@ocforums) had a PWM controller that was much bulkier.
Other than that, its looking great so far. If it turns out half as good as that picture, you'll have a great case.
Ok, so Im experiencing a small technical difficulty. As I was warned by another forum patron, the PWM circuit is causing a horrible buzz with my fan motors. So, Ill spend the next few days researching a solution.
Rondu said:Since you wound your own transformer secondary, with a bit of rework you can take taps out at the voltages you want for your fan and use a simple multiway switch to control fan speed.
Steelmind said:First, a great looking mod/design.
Second, as far as voltage control goes, couldn't you use something like what is used for race car sets. The ones that look like guns. I believe they just use a coiled wire to control the voltage with a slide to control how far along the coil the electricity has to travel. Voila, instant volt control. At least I think that's how they work. COrrect me if I'm wrong.
Maximum fun is important, but don't dismiss this too quickly. A hand wound multi-tap transformer for speed control will be:very true, but that would not be as much fun
Rondu said:Maximum fun is important, but don't dismiss this too quickly. A hand wound multi-tap transformer for speed control will be:
· a modding first AFAIK (PWM is old news)
· by far the most efficient way to control voltage and fan speed
· foolproof (definitely no humming)
· cheap (except for your labor)
em00guy said:you make a very convincing point. I'm having noise issues with my pwm right now. if i can't resolve them then your idea is a definite possibility.
bluesol said:This can mostly be resolved by modifying the shape of the PWM signal. Smoothing the signal from a square-wave to it being more sinusoidal will really decrease the noise. Please see this PDF for more info.
Rondu said:That is a good read blusol, I am working on a PWM circuit myself. But em00guy you should note that your fans pull 2A each and the note says"For very large fans (more than 500 mA operating current), DC speed control may be required." Anyway good luck.
wood said:rofl, meter guts.![]()
Those decals for the meters look rad. I was skeptical of this mod when it started, but you definitely got a good head on you to make this mod so![]()
btw, you're taking some pretty advanced math courses. Algorithms are used a lot in programming, right? What do you plan to do for a living/what do you do for a living?
Sounds pretty cool. But don't fool yourself: I know several scientists who are simultaneously fantastic fry cooksem00guy said:Thanks for the compliments. Well, technically algorithms are used in everyday life. an algorithm is just a step by step instruction set for solving a problem. In computer science algorithms tend to inherit a mathematical manifistation but they don't have to. I'm a computer science student now and I run a small bussiness called the digital self (thedigitalself.com) through which I design web applications for clients. When I finish school i'll prbably turn the digital self into a mathemetics/computer science reaserch firm because I think I'd make a better scientist than a business man. I also think id make a better fry cook than a scientist but that story is for another day.
