But then it's no longer overkillem00guy said:Belive it or not there is some method this particular bit of madness. These blowers are increadibly well engineered producing almost no mechanical noise. It is a persintant theory in fluid dynamics that the pressure created by forcing air through the heater cores causes traditional fans to loose a great deal of performance due to poor tourqe. Because of the non existant mechanical noise i can run these high tourqe blowers at a very low rpm and still best the performace of several 120mm case fans.
On a more serious note, it'll be interesting to see a comparison between your proposed setup and one with axial fans in terms of cooling performance
