cheesehazard
- Dec 15, 2005
Just started modding my new case a little. I was wondering what you guys think I should do with my radiator, use 4 80 mm fans or 2 120 mm fans. I have to go to home depot tomorrow to get some nuts and bolts to finish up the casters I stuck on the bottom of my case and I am also going to go grab some fans and tubing for my watercooling.
I am going to make a shroud for the fans so it sucks the air from the front of the case, where the 120 mm fan is now and forces it into the fans and over the radiator. The fans are gonna be mounted inside the case blowing down.
