Problems with HDD... I think.
Syribo
About a month or two ago, my external HDD began acting strangely. I couldn't access any data on it, and it would slow down my computer to the point where it wasn't even able to be used. The drive was a Seagate 7200.11 500GB HDD inside of an Antec MX1 external enclosure. I tried my other two drives in the MX1 to make sure that it wasn't the problem, and they both worked. I even tried the 'broken' drive internally and it still had the same problems.
So I shipped the drive off to Seagate and just received a new refurbished drive today. I put it in my MX1, hook everything up correctly (I double, triple and quadruple checked the wiring), nothing. When starting up the computer, it didn't even show a third SATA drive.
So I took the HDD out of the enclosure and put it inside the computer and connected it with just a SATA wire. Now I can see the third SATA drive being shown on the BIOS screen and POST screens.. but when I get into Vista, it will not show up in 'My Computer'. Just my other two drives are there.
When I go to Device Manager, it lists 3 SATA drives though... I... don't know what's going on here. Any input? :(
Edit: I should add that I also tried using different SATA wires, and tried different ports as well.
Ah ha, more of an update. I went to Device Manager, clicked on each of my drives and under Volume I went to Populate. For my first two drives, it brought up the info and stuff.. but when I tried for the third drive, I got a Rundll error..
Umm, did you format that drive yet?
Oh my God... no I didn't!
Ugh.. I put in the Vista DVD so I can format the drive that way (I'm drawing a blank.. this is the only way to format the drive, right?) and as soon as it started to load I got a BSOD :(
Trying again now....... Let's see what happens......
Nein.
Boot into windows from your main drive, go to My Computer and you'll see a disk that is 'unreadable' and it will ask you to format. Otherwise, download something like Ultimate boot CD and go from there.
Nein.
Oh God I feel so stupid for not realizing I had to format the drive! I don't even deserve to own a computer :p
Well I just went through the whole Vista installation disc thing and formatted that way... Oops :) Booting up now to see if the drive is readable.. Then if it is, I can put it back in the external enclosure and hope it still works!
YAY It works! It shows up now in My Computer :D And I can use it normally! Thanks for the help.. even though I really should have been able to figure that out on my own :X Stupid me!
We all do stupid stuff.
My first build didn't start up. I had my friend drive 4 hours from his college only for him to tell me the only thing I forgot was to plug in the power button jumper cable. :rolleyes:
