Hells ya! the 8800 gtx still is an awesome card, mine in going in my backup box for some lan action
One question, how do i get that little badge you guys have?
Maybe there is a problem with FahSpy? Or is this normal? The PPD number has been fluctuating a lot, and it's been around 400PPD for a while now.. Do just certain things make the PPD go down so much?
Also, for those who have two SMP clients going in Windows on a Quad-Core, what PPD do you usually get on each client?
PPD shouldn't vary to the extent you are experiencing, but again I haven't installed the GPU2 client yet so my knowledge is next to zero on its typical function. I agree with Xilikon that it's possible a process may have been monopolizing a core, because I have seen that happen with the SMP client when an errant application froze or misbehaved for some reason.Maybe there is a problem with FahSpy? Or is this normal? The PPD number has been fluctuating a lot, and it's been around 400PPD for a while now.. Do just certain things make the PPD go down so much?
Can we change the machine ID mid way through a WU, or is it better to wait for the WU to finish first?This was teh guide to run dual gpus, but it ended up providing a piece of info that might let my dual smps and the gpu play nice...
"The GPU defaults to Machine ID 2" So making your SMPS maybe 1 and 3 might help!
GPU: EVGA 8800gts 320
CPU: E8400 4ghz
CPU load while folding: 100% (running winSMP)
Board Connection: PCI-E
Memory used by the client: 14MB
Temps of the GPU (NVMonitor): 64C (100% fan)
GPU Clocks: 500/1200/800
PPD: 2300ppd from gpu2, 2100ppd from winSMP.
Interesting, I haven't heard any complaints about noise from 8800GT owners yet, but the GTS is a dual-slot card and I imagine the fan is obviously much more powerful.Quite an improvement over the GTS320, but the new GTS512 has the notorious nvidia high pitched whine under load...it's goddamn annoying.
I have an 8800GTX whines..But only when it first starts a unit, or if I pause it and restart it..Its weird it only does it at those times......but I agree..its annoying as hell..Quite an improvement over the GTS320, but the new GTS512 has the notorious nvidia high pitched whine under load...it's goddamn annoying.
give evga precision tool a whirlSunin: If you would please, when you get home, check out your settings and let me know. Haven't quite figured out RivaTuner. Thanks a bunch. Gary
