Post Your Workstations 2018
Before and after pics of a chance I took a few weeks ago going with a Pre-Built from Cyberpower PC.
Shipping was fast, Packaging was Good, all in all a great Mid / High gaming rig that has Character.
There's a couple more little touches before I'm finished so stay tuned.
IMG_20180314_192721.jpg MVIMG_20180321_042904.jpg MVIMG_20180322_015433.jpg MVIMG_20180323_030008.jpg MVIMG_20180323_030017.jpg MVIMG_20180323_030038.jpg MVIMG_20180323_030138.jpg MVIMG_20180323_030722.jpg MVIMG_20180323_030819.jpg
My contribution - 7 computers and 6 monitors in what is a smallish sized bedroom. Until my basement is finished, my office is relegated to a small room in the house. It is where I do 90% of my work when not traveling, and where my dog occupies half the room on a queen sized bed that he has made his layer.
That's what I was on about
NEBULA :Work in progress.Still have to finish the wiring/plumb the water cooling and a few other mods coming.
I dig the setup, but I have to say, the alignment between the three monitors is piquing my OCD pretty hard.
LOL you and me both.Middle monitor is not yet mounted and is sitting on a pile of books .Cant find the right height books to make them even.
Time to break out that ream of paper, 0.1mm fine adjustments :)
work in progress
Almost done ,need to re bend a few pipes and last few mods coming.
Just finished upgrade my PC from last year to this year May 2018 with Mod cables, 4TB HHD, 3 More case fans, 43inch LG monitor, Sony X800 UHD player, Monitor stand.
Tower
You can put up w/ a keyboard w/o numeric key pad?
I've been doing the same for the last couple of weeks. Its helped a good bit with ergonomics for me. I'll probably pick up a separate ten-key to use when necessary (data entry and the like), but overall hasn't been missed nearly as much as I expected.
Tenkeyless is the only way for me, too!
You can also get keyboards with numpads that you can remove and even connect on the left side.
I have 2 of them myself, the Microsoft Sidewinder X6 and the Gigabyte AORUS Thunder K7.
If you want RGB there is the ASUS Claymore.
slowly but surely
Is that a Compaq then? I haven't heard of LS-120 disk and PD Ram drive for a long time. Compaq high end Deskpro series has 1 or 2 models using LS-120 and PD RAM drive. And can you still buy the media for those? Your problem is, by using a case that old, your PSU can't blow the air out.
i made it my self with mdf and rack strip its just two boxes with the rack equipment and two shelves in the middle.
i did have the option to buy them but there was no way they would fit or even get them up the stairs in the first place.
mine are the two rears for there 5.1 setup, tho they went bust thus why i have them ;)
