Bomo
- Mar 9, 2010
Is that 3x GTX460s and one GTX465? Tri-SLI + Physx on the (semi)cheap
According to his signature, there is a 470 and 2 460's. Plus the clearly visible 465 makes it: 1x470, 1x465, 2x460. I'm guessing.
I personally love mine. I have 5 Noctua P15's and it runs them with no problems at all.
I am debating replacing it with the newer version which attaches to a PCI slot on the back of your case and has an external LCD touchscreen you can place within 6 feet of your computer
Zarathustra[H];1036726095 said:My modest system:
Current setup... by mattlach, on Flickr
In 2011 I will:
- Replace the small form factor case, with something bigger under the desk
- Go SLI
- Possibly get side monitors
Zarathustra[H];1036817396 said:Just added one of the side monitors mentioned above, a 2007FP.
Crappy pic. I was playing with automerge and HDR for the first time to expose the screen and the desk right at the same time, but the results are a little weird.
I like this setup. Now I need another 2007FP (must save money)
what monitor is that.
Did you looked at the Dell P2011 before deciding to go with your current side monitor? It seems it would be more suitable for U3011, don't you think?
New 2011 setup in my closet.
New 2011 setup in my closet.![]()
I don't get this fad with everyone putting a TV above their PC monitors. Where are you sitting to use that screen? It seems too high to use as an actual TV and using it while sitting has to be annoying.
Is that even legal? Which state is he in? He's got more guns than I've unlocked in BFBC2
That's very cool! At my school we have Dell Precision workstations with Quadro graphics for CAD. It takes a lot of practice!
HAK5 niceAwesome show
^^ Altec Lansing speakers from 1997 going strong?![]()
Yeah, same here. I've thought about building a concrete desk actually.
That's a very nice desk! Now I'm intrigued to build my own ...
Thanks a lot folks. ^^ I'm glad my dad helped me build it. It came together quite nicely, and is made to use as much space of the room as possible. Works quite well. Could fit two 27" screens. Took about 2 weeks to build it and a day to set it up. Not everything had been thought through that well. If I could redo it, I'd make some slight changes.Yeah, same here. I've thought about building a concrete desk actually.
Custom built desk with cable storage/management underneath. Custom computer shelf. Custom speaker stands/lamps. All of it took about 1'ish week to build/plan/etc.][/URL]
Click through on the image for more pics.
