Formula.350
- Sep 30, 2011
chew* at XS picked up a Taichi this weekend and has had good luck with it. Sure, this is till only 2 sticks, but the key is it's 2 sticks of 16GB running at DDR4-3400
(at stock voltage)
You're reading it wrong, but don't feel bad as it's definitely an easy mistake in general, nevermind when the screenshot was cropped down like that!Yes, but what sticks? From that photo it shows f4-3400c16d-16gtz, which are 2x8GB sticks, though if they are 16GB sticks then they should be F4-3400C16D-32GTZ?
I'm wanting to upgrade my x58 system to a Ryzen system, but this memory thing is holding me back until compatibility is smoothed over.
You're reading it wrong, but don't feel bad as it's definitely an easy mistake in general, nevermind when the screenshot was cropped down like that!(I only figured it out a couple weeks back heh)
They say F4-3400C16-16GTZ
Which translates to Trident Z DDR4-3400 16GB CL16 module. From there, you just apply the SPD timings in the table to determine that specifically it's the 16-16-16-36 variant.
CPUZ's tab doesn't say the Memory KIT name, which is indeed what you put. The difference is one silly letter... "D" which in the kit part number, denotes "Dual Channel", and Q denotes "Quad Channel". As such for those, you would halve or quarter the "-##GTZ" to get the module size, as you had done.
lol Like I said I had only figured out their 'coding' a couple weeks backAh ha! You can tell i'm an x58'er (as I haven't upgraded forever). Thanks for taking it easy on an old-timer and being nice about it, young whipper-snapper!
I'm really interested in the Ryzen platform, but really wanting 32GB for vmware. 24GB is okay on my x58 hexacore, but an octocore 32GB system just seems so enticing. That and all of the IPC upgrade from a basically 990x equivelant xeon.
I'm going to probably wait 2-3 months to let this memory compatibility issue get ironed out and matured before finally upgrading from my old x58 workhorse.
That's been posted about all over. I believe in this thread, too, but if not then in a few of the other threads on [H]. Ryzen has some quirky issue with Odd CAS timings (the first number in the sequence). I suspect it only occurs above 2133 since for me at that speed, 15-15-15-35 works fine. I haven't tried any other speeds besides 2933, and 3200, but can confirm that at either of those speeds odd timings do not work and will auto adjust to one higher (at least on my board). 14-15-15 works, 16-15-15 works, as does 14-13-13 or 12-13-13, but not 15-15-15 or 13-13-13 at either 3200 or 2933. *shrug*Noticed some oddness with my ASRock b350 pro4. Have two sticks of gskill TridentZ 2x16 @ 3000 (15-15-15-35) in the board running at 2400 right now. Bios is the new 2.20, but this is also true for 1.50 and 1.43.
If you push the mem speed in bios to 2400 from 2133, leaving everything else as "Auto", the board won't post. If you actually choose a CL (16 in this case) and change nothing else (leave the rest of the timings as Auto, leaving voltage untouched), the board will now post and be stable. Going back into bios now shows the rest of the timings have been set so the result is 16-17-17-40.
XMP at the CL15 timing is visible but won't actually work if selected. Just some odd behavior.
What board are you running?Running the Flare X 3200 kit now (8GB x 2). Plugged them in, went into BIOS and selected 3200. That was it. No mess around.
lol You forgot to tell us how much your stick cost you, though!How about this!
ASUS PRIME B350M-A with Ryzen 5 1600, and 1 stick of Kingston ValueRam DDR4 2133 8GB KVR21N15S8/8
Results - 2933MHz @ 16-17-17-42 1.3V! Achieving 21GB/s in Maxxmem with just one stick! How good is that! Forget the overpriced Intel XMP memory!
That module is $62 on NewEgg.
I don't suppose you'd be willing to do a test for me, running it at DDR4-1866 at 13-13-13-31 and telling me what you get, and also what version of MaxxMem?
Post 9476 by Gadfly shows 3600 Mhz speed(1800 memory clock)
http://www.overclock.net/t/1624603/rog-crosshair-vi-overclocking-thread/9470
Chew had gotten 2x Double-Ranked modules (8GB though) running at 3400.Single rank seems to be the only ones that can do 3200 from the results listing on the first page of that thread. No 16Gb single rank that I can see..
Edit- Beardless Duck had 4x8 GB running at 3200 on the list.
o_0 Yours... in CPUz, says it's running at CL15 on your motherboard??I edited my op, but now up to 2666mhz cas15 with bios 0604 (new AGESA). No post at 2933c15. Slowly getting there.
I can only confirm it working at 2133 on my Titanium, and might work at 2400 since the new "Memory Try It!" option they added with predefined timings, has a choice of 17-17-17 at 2400.
Otherwise, everyone else seems to have issues running Odd numbered CAS latencies, and at 3200 or 2933, they are set in the BIOS to CL15, but something along the way (Ryzen? Microcode?) forces it to being CL16.
Also for what it's worth, my Titanium with the latest AGESA (in BIOS it reads as 800111C), 3200 @ 14-15-15-35 does not work; however, 3200 @ 16-15-15-35 does.
I'm also able to run it with a BCLK of 102 (max on this hidden BCLK option is 103), meaning 3264 @ 16-15-15-35 is working.
If T1 == Command Rate 1 (CR1), then I knew that it usally does. However, I believe in a screenshot TopWeasel sent me, his was reporting as running at CR2, so there seem to be specific instances when it doesn't "always" run at 1, but his definitely was the only instance I've come across so far.Thought this was pretty interesting (read:boreing)--skip to the last page. Mentions a few thing we know (cas at next even number above certain clocks, northbridge tied to memory clock, etc) and also some which we may not have heard (ryzen always runs mem at T1?).
So how do you like the B350 Mortar? Thinking of picking one up.MSI Mortar B350
BIOS 7A37v12 (just released with the R5 support and - Update AGESA to 1.0.0.4a.
R7 1700 (stock for now, had it at 3.8 locked with 1.25v and 20% LLC in prev bios but havent attemped yet in new bios since I wanted to squeeze the ram)
GSkill Ripjaw V 16gb 3200 : https://www.newegg.com/Product/Prod...&cm_re=gskil_ddr4_3200-_-20-232-181-_-Product 113 bux right now GET SOME
NO its not on for my board but ram prices on 'Ryzen ' ram are just criminal so time to gamble.
Running it at: 2933 14|16|16|34|69 1T
With new bios there is a 'try it' feature with a bunch of ram speeds and timings so I did try a few and this is the fastest freq and lowest timings I can get rock stable. So, still at 2933 but stable with tighter timings on this (3rd) bios release.
Still will not post reliably at 3200 with any timings. I did get a good boot at the XMP settings (input manually in bios) and ran fin all night. However reboot the next day it took a dump and recovered at 2133 1.2v booooo.
Been keeping an eye on this thread, but if anyone can get 32GB (2x16GB) working at 3200 with 14 or 15 latency please post your RAM and settings and MB you are using please
