- Dec 19, 2005
you guys impressed?
Nope,are you impressed
I was only messing with ya but I have not tried higher than 1933FCLK synced. Probably not possible but maybe with enough voltage anything is possible.yah i am, think you can hit 2000 ?
To tell the truth ,with proper DDR4 Ram timings no need to go higher as the results are the same with 1467 FCLK vs 1933FCLK. Even with 2000Mhz FCLK there will be no difference in performance for me. Higher Ryzen FCLK is a myth to me.
Tuned Ram AMD Ryzen Fabric Clock 1467Mhz (DDR4 2933Mhz) vs Fabric Clock 1933Mhz (DDR4 3866Mhz) in a couple games 1080p/1440p
All the settings are at end of video,voltages for memory were just give it enough voltage for stability without errors.Damn, Cas 12 with 230 trfc! Both configurations were within 1-2% of each other. What voltage did you need in the memory?
Ryzen infinity fabric clock is a myth ,if you can set your ram up with tight timings...
