He does or at least it looks like it ?chronic9 said:is it just me or does he have two PSUs in that PC? i see one power cord go to the top and 1 to the bottom. your PC doesnt seem like it needs that much juice... or am i wrong?
Bigboy9247 said:Yes, I have dual PSU's in there, I figured i have the room I might as well get them.
He must have forgotten that the case mod forum is only for needed mods.cornelious0_0 said:Umm...ok....but..........why??? I'm just really curious, because from what I see in that case, there's no NEED for two power supplies...and it'd clean up the look of the interior a lot to yank out the bottom one.
usually dual PSUs are good for redundent servers,extermely overclocked VGAs and maybe crazy cooling systems??
JL_Audio_User said:Looks good but please take the tag off the IDE cable. The blue matches nothing and it looks amateurish to leave it there.
Besides that it looks real nice and your wire management is right on
towert7 said:Volkswagen, is there a reason you did'nt attach the SATA hard drive to a SATA connection much closer to the side of the motherboard, instead of dead in the middle?
If you could put it right near the hard drive, that would look quite a bit better.
Woah dude clean that case! The Zalman flower looks like a ball of fuzz!extreme4377 said:Just thought Id throw in some newer pics. Click to enlarge and enjoy
extreme4377 said:ya, I need to clean the HSF. whats the easiest way of cleaning it? Id rather not remove it but if I have to I will I guess.
TheMostWantedPolishTwin said:It looks to be sleeved so feel free to do whatever you want to
cornelious0_0 said:i like the look of the zip-tied Tt NB cooler...and even though it's not perfect, the paintjob inside the stacker is alright.
Oh right...the wiring.....
.....eh.....the biggest thing that stands out to me is the ccfl at an angle there...would it really be that hard to have it going down along the board perfectly vertical? Other then that, even though the cable would be sticking out more....i still think it would look better if the ATX cable came out through that hole in the PSU cage and then down to the connector. The SATA cable looks like it could be pulled tighter...and it's too bad you don't have more slack on that fan, to run the cable under the board..and then out under it from the right side to the connector. you've done fairly well with the rounded cables...and it actually looks fairly orderly....but IMO it'd be better with black rounded IDE's.
ill_killa said:thanks for the tips keep them coming guys i can use all the help
DlStreamnet said:[IG]http://www.supload.com/thumbs/default/picture00019.jpg[/IMG]
[IG]http://www.supload.com/thumbs/default/Pc (4)-967122.jpg[/IG]
