Heres mine. It's a modded compaq case, I reversed the hard drives, and tightened up the IDE cables. Ignore the CCl cables and the power switch, there just temporary.
http://i41.photobucket.com/albums/e286/NukeULater/Project Mechaniod/ProjectMechanoid_9.jpg
http://i41.photobucket.com/albums/e286/NukeULater/Project Mechaniod/ProjectMechanoid_10.jpg
A few UV lights/sleeving for the un-hidable wires.
What case is that?Right first attempt at tidying up my rig.
Meh, my Antec P160. First try at cable management. Flame on.
Exterior:
Exterior Showing my 1337 Lighting(Didnt want to over do it)
Mobo view
Hard drive rack(w/ flash)
Interior
Close-up
What case is that?
Look at my sexeh rig!!! Ya baby! This was in testing phase. and I dont have my lights in there yet!
g33zy: that looks great
amd rules: i agree the c5 is hard to hide wires in cause its a small case (i had one but it was too tight
gobygoby: that looks a lot better, if you wanted to hide those sata cables more (i realize their uv and if you gota show cables they might as well look cool) you could drop them behind the board and have them come out the bottom, then all you would see for the most part would b ur water tubes
dont flame me on my wire mangement. It's a coolermaster centurion 5 and it has to be one of the hardest cases to hide wires in. So here it is:
[IMG]http://img409.imageshack.us/img409/1061/pictures001ai6.jpg[/IMG]
[IMG]http://img178.imageshack.us/img178/2417/pictures002jo8.jpg[/IMG]
[img]http://img252.imageshack.us/img252/9194/picturesoo3.jpg[/img]
another reason why i don't like Mid towers
Here is the 99% finished version.....
I made a false foor and a false wall next to the mobo to hide all the wires.....and the thin vertical false wall next to the drive tower hides a ccfl.
How did you mount the false walls/floor? I was thinking about doing something similar in my tt armor. . . i've been thinking about doing a lot with mine actually. . . haven't gotten around to it yet. . haha
Roguetrip: I hope you are DEFINATLY going to be buying a quality psu.. Really. Such nice components, such bad psu.
What fan is that? The blue one? Is that just a custom job?
Check out my build log here...
Everyone bashes this PSU, dunno why, I bought it back on 10/17/2004, i resoldered the board shortly after and been using ever since with no problems, and voltage is within spec. I know about the horror stories but if you just resolder it before they become a problem (lots of cold solder joints will happen) then there won't be a problem, also rebuilt the 120mm fan on it a year ago with some air tool oil and its been running great!
From the man himself:
http://www.jonnyguru.com/PSU/Assassin/Powmax_Assassin.html
http://www.slcentral.com/powmax-demon-580w-psu/
The guts lack substance. Doesn't do even 300w properly, .69 pf, 72% efficiency..
The sata cables are the last thing I have to work on. I am gfoing to make them go straight up instead of how they are now...
ps. they are el sata, not UV.
Lupine, that I built for my wifey... was a Cent 5. With some minor cutting to the case frame, a few feet of electrical wire and some 90 degree molexes, you *can* clean up the internals on a Cent 5.dont flame me on my wire mangement. It's a coolermaster centurion 5 and it has to be one of the hardest cases to hide wires in. So here it is:
I have the cables routed behind the mobo tray and behind the 5.25 bays. I have a custom power cable that I built that attaches to the hard drive nad the optical drive.
Granted you have more "drives", but the premise is the same.
Turn the SATA drives around and back feed the connectors. If there is not enough space, make a hole!
MOD IT!
Keep up the excellent work!
Various internal shots:
This is one of my favorite shots...
Heres my Stacker. Any opinions or suggestions?
@Tech-Daddy - I really like that. Where did you get those coils that go over your cable?
