xp90? you must mean si97CCUABIDExORxDIE said:you could also run the 20pin and 4 pin mobo connectors around the xp90 upwards, it would look better imo.
Per suggestionCCUABIDExORxDIE said:you could space your two optical drives farther apart and then fold the cable up in between them, and using flat ide cables could help you ALOT, they are really easy to hide and easier to work with then those huge bulky antec cables.
N H O said:xp90? you must mean si97
you gotta push it harder so that the vtec can kick in y0!JDM-Y0- said:Does my Sh!t not look good?
g33zy said:you gotta push it harder so that the vtec can kick in y0!
lol, j/k, you gotta take some more pics. That crooked side angle cut off pic ain't showin us much.
4X4N said:And the wifes lanboy.
Bathazar said:
Here is a pic of my cable managment in my Thermaltake armor. I only wish I could hide the round cables.
What do you mean? I found only one, to plug the HSF into, but where can I plug the GPU HSF into? Can you give me a hand? I had to do that because I plugged it in with the 120 exhaust fan in the back.g33zy said:I can't even hate on the case, it looks awesome.
The wires that you have showing can be hidden, just get a little creative and try some different routes. Most of the major wires are sleeved already so you don't have to go too crazy with that.
The only wire thats really bothering me is the fan wire, looks like it could be the wire for the GPU fan. If you want to do something to hide it a little better, plug it into that fan header right above the card. I have the same mobo and use the zalman gpu coolers and plug it into the 3 pin connector on the mobo. Just bunch up and zip tie them as short as possible and plug it right in there.
hybrid.09 said:Did you mean plugging the Zalman Power Connector from Power Supply to Fan into the molex connecter on the mobo and doing it that way? Or another way? :|
m3ta1head said:Looks great dude! 9/10.
Maybe remove those asus flaps from the IDE cables to make them look more sleek?
