Post your pc screen shots!
my screen shot
Here's a new XP ss:
(Sunday! is a BMX company, I have their frame for my bike as of now.)
MacBook Pro Santa Rosa
Yeah ok Vista lovers I dual boot. I can post my XP and Vista screenshots from my gaming rig, too heh.
I believe that wallpaper is part of the Apple wallpaper set. It should be pretty easy to find, google it.
Not to be an ass, but, why? Thats where I got it, so it made sense to link it?
edit:
Here is an actual screenshot for you, to avoid hurting any feelings.
edit:
No hurt feelings man....just didn't want to see it get deleted... that's all..
where can i get some vista aero themes?
and some dreamscene? preferably free. lol
http://img222.imageshack.us/img222/3259/capturelc5.jpg
*Where I come from they did not give us names....They gave us numbers....*
**Then what is your number?"
*They call me....47...*
Movie looks pretty bad ass, cant wait to see some of the first real trailers!:D
is that a apple only chat client? i like how its broken up into small bits for each group of ppl.
I run trillian (non-pro) on my windows machine and I can break it up into any type of groups I want, including sub groups. There are others for PC such as Miranda which has by far the best customization for any AIM/MSN/etc. client, but it can be a pain to setup exactly how you want it. I compare it to Foobar, looks great, runs great, etc., but takes a bit to setup how you want. If you want a nice easy one with some nice customizations (easy to setup) check out trillian.
I must ask then, since I really enjoy your setup.
What are you running? Windows Blinds or VS, which theme, plus anything else (such as your folders and bottom bar).
Thanks. :)
The skin I'm using there is Kuro, for Windows Blinds. It's also available in VS format, but I don't have a link to it. :/
The app used to emulate the finder style taskbar of OS X is Objectdock, also using a Kuro skin.
The app controlling the folder icons, CD case, and various other things that aren't visible in the shot is Avedesk. It's a bit like Google Widgets, but it's less resource heavy.
Finally, the dock at the bottom is RKLauncher. It's essentially the same thing as Objectdock but, like Avedesk, is much less resource heavy.
Thank you very much.
I got it all up and running other than how do I get the glass text style bar? I use to use Objectdock and never could never figure it out, then tried rocketdock but I forgot to give it a try, with this setup I really want to try to have the glass text style, any help.
