*POST* your i7 setup specks
I got my Thermalright Ultra Extreme installed again and it looks like 3.83GHz 1.35v is going to be it for me. Unless I figure something else out.
for uncore and qpi voltages what are the best settings.
bump it by around .05-.1v, and see if that helps. Goes back to that anandtech article I linked before.
As for best, dont ask me. My board/ram wont be here until thursday (I hope).
Did you bump the uncore/QPI voltage at all? Its supposed to be pretty effective.
Otherwise, it doesn't sound that off, voltage can be pretty chip specific.
But im running faster qpi @ 19 multiplier, 211 vs 200. Ill give it a try, but doesnt make sense to me to increase voltage when its running slower than it currently is.
Right now though for the average user is there a benefit of 6gb of 12gb of ram??
MSI eclipse
Core i7 920
CoolerMaster V8
G.Skill 9-9-9-24 1600 3x1gb (will add another kit of these for 6gb later)
RocketRaid 2310
2x Raptor 74gb (raid0) (system, games, and apps)
2x 500gb Seagate 7200.11s (raid1) (media storage)
2x SATA DVD drives (LiteOn and Plextor)
2x MSI GTX260s
Kingwin Mach1 psu
Sunbeam 9bay acrylic case
UV lights and fans..
Vista64 home prem
I have a bunch of these parts and some I am waiting on, but it's trickling in here... I should have it all by next weekend. the plan is to build a whole new gaming rig, sort of a "base build".. get that stable, then move my video cards and whatever else I want to move to the final build. I hope to hit 3.8+ ghz with the cpu.. I'll stick with air cooled for now, but bit go water later with my modified nautilus 500.. we'll see..
Just tried mine out @ 4ghz, Vista loaded no problems. I checked my idle temps and they ranged between 40-45c, which I thought was pretty good since its was right in range the Kyle hit his with OC and Temps test. I fired up Prime95 in about 30 sec the cores jumped to 90-95, I 100% increase ><.
ASUS P6T Deluxe
core i7 ??? - work perk. faster than 965 EE.
Noctua NH-U12P SE1366
G.SKILL 6GB (3 x 2GB) DDR3 1333
Intel X25-M SSD for boot
Sapphire Radeon 4850 X2
everything else is irrelevant. hopefully all the parts arrive mid next week.
not counting live search cashback, it cost around $1000 including the true black and shipping.
with 2x hd4870, 80gb velociraptor, 1tb sg 7200.11, zalman 1kw.
set vcore to 1.35, vdimm to 1.65, bumped vtt and vqq up a couple steps and boot into v64 at 20x200. prime stable for a few hours. the true, true black and true black se are being sold as socket 1366 hs in many online stores. they do not come with socket 1366 mounting hardware. i had a 1366 bolt thru kit i bought for my ultima 90 a few weeks ago. the bolt thru kit cam back in stock today at jab-tech and sidewinder.
Here is mine
Intel [email protected]
Asus P6T Deluxe
CM V8 Cooler
CM Stacker (Black) 830
CM 1000w PSU
6GB Patriot DDRIII 1600 Ram
EVGA GTX 280 SLI
WD 300gb VelociRaptor
WD 150gb RaptorX
WD 1TB Storage
WD 750GB x 2
LG CGW-H20L Blueray-HD Writer/Reader
Microsoft Vista 64bit
Faithful 37" Westy
I finally got my machine all together and powered up... it works! whew... nearly had a heart attack when I flashed the bios and the system hung at cpu ini.. but a cold boot fixed it. whew...WHEW.
edit: better photo (than the first one)
the system ended up as:
core i7 920 (batch 3837a714 rev C0/C1)
CM V8
MSI eclipse (bios 133)
GSkill 9-9-9-24 1600 1gb x3 (going to add 3 more 1gb sticks soon I think)
Areca arc-1200 caching raid controller
2x raptor-x raid0
1x Seagate 500gb 7200.11
Plextor px-755a + crappy Asus SATA DVDrom
XION supernova 1kw psu (same hardware as Kingwin 1kw)
I will OC this to a stable spot I am happy with then add my two GTX260s and my pci x-fi...
Possible Ncix build,
Intel Core I7 920 Quad Core Processor
Noctua NH-U12P SE1366 LGA1366 I7 Heatpipe Cooler
ASUS P6T Deluxe Motherboard
Corsair XMS3 3GB DDR3
XFX GeForce GTX 260
Cooler Master Haf 932 Full Tower
BFG ES800 800W Power Supply
Microsoft Windows Vista Home Premium Edition 64BIT
Western Digital Caviar SE16 640GB HD
Samsung SH-S223F/BEBS 22X Speed Plus Black SATA DVD Writer
Onboard Sound
case: antec p182
PSU: corsair 520w
CPU: i7 920
HSF: noctua nh-u12p se1366, using both fans in push/pull
mobo: P6T
RAM: 3GB corsair DDR3 1600
video: 8800GTS 640MB. (I do more than game on this box.)
Currently running at 3.5Ghz (3.6 with turbo mode) at stock voltage. Peak temps around ~75C at full load. I'm very happy with this setup. Fast and quiet.
What do you think of this build? I will be building it ASAP.
Core i7 965EE
TRUE 1366
EVGA X58
6gb Corsair DDR3 1600Mhz
3x GTX 280
Silverstone TJ07
300GB Velociraptor
1TB WD Caviar Black
Corsair 1000HX
Dell 3007WFP-HC
i7
CPU
920
MB
P6T Deluxe OC Palm
RAM
3Gb OCZ Gold 12800 1600Mhz
OC settings
24/7 -- CPU 19 x 206 BCLK | 3.91Ghz | RAM 1646Mhz 8,8,8,24,1T
CPU - 1.325v
CPU PLL - 1.96v
QPI - 1.35v
DRAM - 1.68v
Cooling
Akasa Nero with 1900rpm 120mm
Antec 900 3x1200rpm 120mm + top 200mm @ High
Temps
Idle 36c-42c
Load 76c-82c
Why?
I was waiting for an upgrade from my Shuttle SN25p
CM V8
2x raptor-x raid0
Holy glowing stuff Batman!!!
Here's what I am running right now. Idle temps around 28c and max around 59c
Intel Core I7 920 @ 3.8hz 1.35vcore
Thermalright IFX-14 Cooler with Scythe
Patriot Viper DDR3 1600 12gb (6x2gb)
2 Gigabyte 4870x2's in Crossfire
Antec 1200
Corsair HX1000
Microsoft Windows Vista Ultimate 64bit
4 Western Digital RE2 500gb's in Raid 5
Samsung 46" Lcd 1080p
hay guys my computer is alive today.
920
MSI X58 Platina
2x2gb G.Skill 1333 (oddly, it was the cheapest $/gb on egg)
nv 7300LE (pretty awesome huh)
there is no case, cases are lame
250gb Samsung HD / 320gb Seagate 7200.11
Win Server 2008 x64 (I plugged in the HD straight out of my e8400 system, booted normally no problem! Work to do, no time for wiping.)
OC to 3ghz using stock Intel heatsink by changing bclk to 150 and leaving all other settings. I will mess with it more when I have time.
34 idle / 57 full load (lightwave rendering 16thread)
Specs are in the sig, haven't tested the temps yet or ran Prime 95, system has only been loaded up since last night with all the drivers.
Running XP 32 bit at the moment (so my older games will still work), will put Vista on at a later date.
The only games that wont run on vista x64 are 16 bit games. And for them, a virtualized box is plenty to run them just fine.
latest build:
CPU - i7 920 Nehalem
Mobo - Asus P6T
GPU - XFX GeForce 9800GT
PSU - Corsair 620W Modular
RAM - Corsair DDR3 1333 12GB (6 x 2GB)
Case - Antec Three Hundred
DVD drive - Samsung 22x SATA LightSribe
Hard Drives:
WD 300GB VeloRaptor SATA
WD 2x640GB AALS Black SATA
WD 2x320GB Green SATA
WD 250GB Caviar SATA
OS: Windows Vista Ultimate 64 bit, Windows 7
Monitors: 3 x 20" ACD Apple monitors - 2 connected to this PC and 1 connected to MacBook
Keyboard - Apple wireless mini
Mouse - Logitech MX Revolution
cpu: i7 920
mobo: msi x58 platinum
memory: crucial 12gb ddr3 1333
gpu: evga geforce 260 (1st edition)
psu: 80 silver certified 1050w
monitor: samsung sm 2693hm 26" 1920x1200
ssd: intel x25-m g1 80gb
ssd2: patriot memory 64gb
os: win7 64bit home premium (oem)
i got this mobo because it was the cheapest x58 available
CPU - i7 920 Nehalem (NEW)
Mobo - eVGA X58 3xSLI (NEW)
GPU - eVGA 8800GTS 512 g92 (From old rig)
PSU - OCZ GameXStream 600W (From old rig)
RAM - Aeneon Xtune 6x1GB DDR3-1600 (NEW)
Soundcard - Soundblaster X-Fi Fatal1ty (From old rig)
Case - Antec Nine Hundred (From old rig)
DVD drive - Lite-On DVD-RW SATA (From old rig)
Hard Drives - WD 400GB SATA (From old rig)
OS: Windows XP 64-Bit
Monitor - Samsung SyncMaster 740B 17" (From old rig)
Keyboard - Microsoft Comfort Curve Keyboard 2000 (From old rig)
Mouse - Logitech MX-518 (From old rig)
CPU: I7 920
MB: EVGA X58 3xSLI
RAM: 3*2GB SUPER TALENT CL9
OC settings: [email protected], QPI PLL 1.325v, VTT 1.325v, HTT on
Cooling: TRUE
Temps: IDLE:40c; LOAD:70C
I got the MB for $CAN 250, the memory for $CAN 125 and the CPU for $CAN 330 (shipping and taxes included for all components). I upgrade my CPU on an annual basis and I was happy with the upgrade net cost. I might be looking eventually for a water cooling solution...
__________________
CPU - i7 920 @ 4GHz
RAM - 6GB OCZ Gold DDR3-1600
MOBO - EVGA x58 SLI
GPUs - Two EVGA GTX 295's in Quad-SLI @ 675/1500/1200
HDD - 300GB Velociraptor
Optical - LG 20X DVD±R SATA GH20NS15
Misc - Hauppauge HVR-1250 tuner
PSU - Zalman ZM850-HP
Case - Lian-Li v1000b
OS - Windows 7 Ultimate x64
Monitor - 37'' Westinghouse LVM-37w3
Keyboard - Logitech G11
Mouse - Logitch G5, funcpad 1030 mousepad
[email protected] wif TRUE120 Copper ED.
FOXCONN Bloodrage
12GB G.Skill 1333RAM
10TB HDD (Total)
2x eVga GTX295
Lian-Li v1000b
1.5k PSU
Windows 7 64bit
Windows Server 2008 RC1
Logitech G9X Mouse
Sidewinder Keyboard
I like ^
CPU: Core i7 920
MB: ASUS P6T Deluxe OC Palm
RAM: 6 x 2GB Corsair Dominator DDR3 1600 8-8-8-24
OC settings: No OC yet, still installing/setting up
Cooling: Noctua NH-1U2P + 2 x NorthQ NQ-3711RL
Temps: (LOAD) CPU 62C / Mobo 55C (Running SETI@Home for 6 hours)
Here is my most current configuration information:
Silverstone TJ-09B
Thermaltake ToughPower 1200 watt
Intel Core i7 920 D0 @ 4.0GHz
Koolance CPU-350AT Waterblock
Koolance Exos 2.5 (Black)
Koolance LIQ-702 Fluid
Fittings + Quick Disconnects
EVGA X58 3X SLI Classified (144-BL-E759-A1)
12GB Corsair Dominator GT 2000MHz DDR3 (6x2GB)
2x Intel X25-M 80GB Gen 1 (RAID-0)
Sasmsung DVD-R/RW Drive (SATA)
3x BFG Technologies Geforce GTX 280 OC (3-Way SLI)
3x 120mm Yate Loon case fans
2x Silverstone 2.5" - 3.5" SSD Mounting Kit
Deck ICE Legend
Logitech G9x Laser Mouse
Dell 3007WFP 30" LCD Monitor
CPU: i7 920 2.67GHz HT & Turbo enabled
MB: Asus P6T Deluxe (V1)
RAM: 6x2GB RED G.Skill DDR3-1600 @ 1333
GPU: Evga GTX 260 216
PS: Corsair 750TX
COOLING: Stock Intel
CPU:i7920 @4.0 Ghz (HT on)
MB : Asus P6T
Ram, 3x2GB Corsair DDR3-1600
GPU : 4870X2 Asus
PS: Corsair 750TX
Cooling : Mugen Scythe II
CPU: i7 920
MB:
evga x58
RAM:
6gb g.skill ddr3-1600
OC settings: managed to hit 3.8ghz so far
Cooling: TRUE (wondering if having a push/pull setup would be better than just the fan pushing)
Temps: 76-81C on load
i7 - 920
P6T
12gb OCZ 1600 http://www.newegg.com/Product/Product.aspx?Item=N82E16820227388
using Windows 7 and its doing amazing so far. (still downloading drivers, etc)
not OC'ing yet. (forgot to order 1366 back plate for my cooler!!!!) :mad: using stock cooler in the mean time.
I choose the P6T based mainly on the review at [H] and reading the forums here. Also the board was a open box that only cost me $167 (showed up as a bare board)
I upgraded from the system in my sig. so it was a big step up for me (but i felt like i was shooting a trusty old dog when I pulled my IC7 apart :( )
CPU: 920
MB: Gigabyte EX58 UD4P
RAM: 3GB crucial ballistix tracer ddr3-1600
VGA: 4850X2
case: mid tower
OC: 3.3 (24/7)
cooling: thermalright ultra 120 EX
Temps: Idle: below 50C. Load: ~62C. Max testing Load: ~66C.
room temp: ~27C
CPU: Core i7 920 @ stock
MOBO: P6T
RAM: 6GB OCZ ddr3-1600
GPU: XFX ATi 4890 1GB
PS: Corsair 750TX
Temp: Idle - around 40C
load - 50-55C
Most all is in my sig. I'm running mixed GTX 260 Tri-SLi. That's two Core 216 cards with an old 192SP card.
i7-920 DO stepping (SLBEJ) @ 3.6GHz (I have gone over 4.0 easily, but diminished returns on performance make 3.6GHz more practical).
Ram: OCZ3X1600LV6GK (2GBx3 OCZ 1600 XMP Ready)
Mobo: Asus Rampage 2 Gene
Sound Card: Creative X-Fi Titanium Pro (Fheggytality branded)
HDD: Samsung F1 1TB x2 (one runs XP pro 32-bit, one runs Vista-64 bit)
PSU: Enermax Rev85+ 1050w
GPU: BFGtech GTX285
Case: Lian-Li PC-A077B (gutted: no front bays for passive cooling, no fans)
Optical: Asus QuieTrack SATA DVD player (I havent needed a burner in years)
Cooling: All water cooled via 8' tall external passive radiator/eheim 1250 for flow...
http://www.hardforum.com/showthread.php?t=1399592
Mouse: Logitech G9
Speakers: Logitech Z5500 THX
Keyboard: MS Natural Multimedia KB... looking for a good ergonomic vertical to replace.
Monitors: BenQ G2400WD + HP p1230 CRT (22" mits tube).
Free Headset + Mic from the Battlefield 2 pre-order bundle (they actually kick butt)...lol.
