furiousfords89
- Apr 17, 2004
A OPA2134.magnetik said:which opamps come with it? ?
I put a 8066 in strid3r's.and what did you replace them with?
magnetik said:damn.. those must hurt!Do you amp em? lol
strid3r said:Got the connector, techflex, and heatshrink off of partsexpress for roughly 7 bucks and shipping. The cable was about 11 shipped off eBay. Of course, I have a lot of leftover material leftover, about 30ft of cable left and didn't even use half the heatshrink and techflex I ordered.
compuguru said:Got any links for those parts? I just ordered those cans and I may want to recable them...
I looked on parts express but I wasn't sure which size techflex or heat shrink to get.(1/8"?)
Also, what type of wire did you use? (plain speaker wire? 1/16"?)
Thanks
- Jay
I assume you mean 1/8" techflex and 6mm heat shrink?strid3r said:I used 1/8" techflex and 6mm techflex (1/4"?).
wow my Triports are even on [H]saturnine2 said:Oh noes! I went off the deep end!
I got the Triports cheap from MrSlacker @ Head-Fi. He found them on the side of the street!The left side isnt working, but I inspected it and its just a loose connection. I'm gonna recable them with a Senn HD580/600 cable, and try out some Blu-Tack and fiber fill.
Bleed said:just got my Grado 325i
They are great for most music with the right amp, no doubt about that. For gaming though, they are seriously lacking. The soundstage sucks compared to other cans in the pricerange.MrPrez said:Are the 325i some of grado's best? Or, more importantly, would they be good for lets say, music, and Counterstrike?
towert7 said:Hey ColStripe, how's that headphone stand working out? I was thinking of buying one of the single ended ones.
Is the build quality good?
~Thanks
saturnine2 said:They are great for most music with the right amp, no doubt about that. For gaming though, they are seriously lacking. The soundstage sucks compared to other cans in the pricerange.
If you HAVE to use a Grado headphone for gaming, I would recommend the RS-1 or PS-1.
MrSlacker said:wow so many headfiers are also on [H]
Vurry niceMister X said:PPA #47 lives.![]()
saturnine2 said:Vurry nice![]()
Yup, wanted a clean look so the power switch went on the back.saturnine2 said:Where is the power switch? On the back?
saturnine2 said:You know what number mine is?
towert7 said:Cool looking little amp you have there cypher22, nice window you added. How's the thing working out for you and about how much did it cost to build that one. Have you used any other amps that you can compare it too?
Maybe if my creative skills improve, and I get some time, ill try and build a little amp myself.
~Thanks
GodsMadClown said:Use the ABX plugin in Foobar2000, kernel streaming to a decent soundcard. You can tell the difference every time between lossy and lossless. Even 320 CBR LAME, MPC or OGG.
Mister X said:![]()
PPA #47 lives.![]()
Circuitbreaker8 said:Looks sweet, would look better w/ clean screws instead of phillips.
DaRkF0g said:Jesus Mr. X, your worksmanship on those amps is nothing short of amazing! Now to make ones with bass and treble adjustments![]()
