ivandurago
- Jun 5, 2008
Complete with distortion![]()
That made me LOL
I will have to show these pics to my bro (he is the musician of the family.)
My Technoredneck air conditioner (patent pending)
-Tad
Did you seriously need a 1kw PSU in a SFF pc?My contribution!
I had to have some kind of support for the heavy Corsair HX 1000W power supply, so i uhh.. yea. Self explanatory
Don't know if this has to be hardware only but here one I did to my truck.
I must say that this was very cheap and it really helped too.![]()
what are you using as a filter? or do you want to blow your engine up?
K&N filter + Built in metal screen behind the air filter.
And if the engine blows then good reason to swap it for a 4.7L v8 or a get a new 5.7L v8.![]()
wat i dont get is why nobody ever does somthing like this
http://img710.imageshack.us/i/goodyetcrazyidea.jpg/
It can look pretty if you spend enough time on it. Which reminds me, I need to get some of those fabric bands. The bike tubes transmit far too much noise.
I would think that would be louder than fabric. Have you seen the little bands that come w/ the Antec P150's? The newer ones? They're already loops so I wouldn't need to tie a knot either.Stretch Magic is what you need.
You can find it at any Michael's or any other arts & crafts store in the Beads section. May sound weird, but this stuff is the best for reducing HDD vibration. I can barely hear my suspended Samsung F1 these days.![]()
I ran out of molex to PCI-E adapters, so I made some:
Painted, cleared and waxed MDF. Easy Button is power and tin can for wifi ant.
Before when I got this Lian Li A77B full tower case, there was this tacky useless fan monitor on the front. It wasn't even a standard 5.25" bay, it measured slightly less than one and half inch. Bought a Lian Li standard cover and used a jigsaw on it.
BEFORE:
Taped up with 2 kinds of tape and used a sharpie to cover up the silver spots where I messed up.
Finished product, pretty ghetto behind it though, don't push it, it'll fall right into the case
Not much else to show really...
hub wired
and the reservoir with pump submerged
I put the 6 machines in to start, with hopes of adding more later, but it never happened. The 2 on top stayed air cooled. The big issue was hard drive and board temps. Lack of airflow in that cabinet and the combined heat of everything was hard on old parts. The doors had to stay open and I had to run a fan in front to keep it happy. I'd recommend an open rack to anyone else, just be careful to insulate/isolate any metal.
I built 8 headless AMD crunchers out of leftovers, and bought the small obsolete drives and PCI vid cards from a surplus guy for about $20. I monitored everything from my desktop with TightVNC. The biggest kick in the junk was buying the water blocks and that big Eheim. That loop was almost 20' long (boards were plumbed in parallel using plumbers manifolds) and the Eheim worked flawlessly. Priming the loop was a challenge though.
why not have this going to a household rad for heating the room
If the only thing keeping those brackets together is friction, it's not going to hold.Enough lurking, it's time for my first post :3
I found these 2 spare PCI brackets today and thought that i have to do something useful with those.
Because I haven't found any proper stand for my headphones, I figured that I could get a temporary headphone hanger.
No glue, tape, soldering or anything similar needed.
http://img13.imageshack.us/img13/4047/bighx.png
Sorry if there are grammar errors, English isn't my first language![]()
