Post your "Ghetto Mod" pics
Discussion in 'Case Mod Gallery' started by wolfofsin, Apr 25, 2005.
  1. charger89
    charger89 Limp Gawd
    162
    Feb 4, 2009
  2. DumpsterDiver727
    DumpsterDiver727 Limp Gawd
    129
    Dec 20, 2006
    I did it a while ago, but I ghetto modded my PSP. Here if you want to see it.
  3. caddys83
    caddys83 2[H]4U
    3,330
    Feb 14, 2009
    My getto Mod. I couldnt find the case brand anywhere. Its like 6 or 7 years old. :eek: It get the job done.:D
    [​IMG]
  4. jtg1993
    jtg1993 Gawd
    811
    Apr 25, 2008
    Nice, I remember seeing that while looking for mods to do to my psp.
  5. Pylon
    Pylon [H]ard|Gawd
    1,299
    Dec 28, 2008
    Quick and dirty one to hold me over until I build a cooling pad.
    [​IMG]
  6. N H O
    N H O 2[H]4U
    3,732
    Nov 10, 2004
    [​IMG]
    [​IMG]
    works out pretty well:
    [​IMG]
    [​IMG]
  7. Mewohkie
    Mewohkie [H]Lite
    88
    Feb 14, 2005
    I wish i had some pictures of my old PC built out of a cardboard popcorn box!
  8. Cursed
    Cursed [H]Lite
    115
    Feb 1, 2009
    Well, my case has no 120mm fan mounts, and all my 80mm ones are full anyway. So I thought, where am I going to put this 120mm fan? The answer was of course to mount it in the drive bays. So I created a cardboard insert, put the fan in, then secured it using string:
    [​IMG]
    [​IMG]
  9. munkynutz
    munkynutz n00b
    59
    Apr 10, 2009
    nice.. but where's the "duck" tape :)
  10. Cursed
    Cursed [H]Lite
    115
    Feb 1, 2009
    Sadly I only had electrical tape at my disposal. I'll have the reupload the images (IsaraPix's host deleted everything by accident, and there were no backups).
  11. nicky.82uk
    nicky.82uk n00b
    52
    Nov 30, 2008
  12. Wibla
    Wibla Limp Gawd
    315
    Jul 9, 2007
    [​IMG]
    vmware testing rig.. p5w dhd, 6 gigs of ram, e6600, 320GB IDE with SATA adapter, lol..
  13. Funkmaster_A
    Funkmaster_A [H]Lite
    84
    Nov 22, 2007
    Should look like this...
    [​IMG]
    But one of the paddles broke...
    [​IMG]
  14. Zero82z
    Zero82z [H]ard as it Gets
    27,897
    Jan 20, 2004
  15. Hypernova
    Hypernova [H]ard|Gawd
    2,028
    Jan 16, 2007
    That actually has a post-modern art feel to it.
  16. Riveninside
    Riveninside [H]Lite
    89
    Jul 9, 2005
    [​IMG]
    only pic i have.
    notice the power supply coming out where the 5 1/2" ports are?
    my heatsink was too big...
    ended up taking a dremel to the top of it and put it back in place, gotta love it!
  17. robtrevino
    robtrevino [H]Lite
    117
    Oct 29, 2007
  18. Jenga
    Jenga [H]Lite
    73
    Nov 12, 2007
    Wow... You are full of WIN!
  19. Uncle Humjaba
    Uncle Humjaba Limp Gawd
    408
    May 6, 2006
    So my external hard drive didn't come with a fan... I have a 1tb wd caviar "black" in it. basically, it was in my main rig, which is in storage where I go to college now... didn't want to leave my movies in south carolina, so i got an external enclosure for it and brought it home to california with me. Anyways, this thing gets pretty toasty after a while, so I decided to employ some cardboard and an old 80mm fan I had lying around for some active cooling.
    [​IMG]
    [​IMG]
    [​IMG]
    Yes, I used a needle to poke holes in the power cord, and the fan is going straight to it. I need to get a switch so it's not on whenever the thing is plugged in.
  20. VA Supremacy
    VA Supremacy Limp Gawd
    475
    Jun 18, 2009
    Prolly should do a window just for the fun of it. Cable management and put 2 fans. for some reason there was no fan on the back so i had to put some old one in. The LED fan has to be there. It stopped being a wonderful compu a few years back and it overheats so I had to add both. Its from August 2001 got it for school. Compaq's not too bad. i rather buy a mac or lappy or build one now=)
    [​IMG]
  21. Breex243
    Breex243 Limp Gawd
    252
    Jun 9, 2009
    God I wish I had a good camera back in summer 2004. Probably the ghettoest cooling mod ever on a Compaq lappy. Had the same 2.8Ghz P4 as my desktop. Toasty as hell. First the plug to the power adapter melted/burned and I stripped the lappy down to the mobo and resoldered a $3 jack. That's not the mod though-just make a point on how hot the laptop was. Temp monitor indicated 104C. yes, Celcius, and that wasn't even the core temp.
    So, it's 90F in the summer and I needed this lappy to work during my internship. Zip-tying a fan wasn't going to be enough. Ice was the answer. Three massive blocks of re-freezable ice was. Carefully placed to balance the lappy and not block airflow, I was able to make that POS last the summer. Forgetting to freeze the ice packs = another 7or so hours of downtime.
    Kind of makes me want to design Core i7 laptops with removable ice inserts.
  22. dragnandy
    dragnandy Limp Gawd
    198
    Jul 28, 2008
    ..is that a, pencil?
  23. furiousfords89
    furiousfords89 Gawd
    712
    Apr 17, 2004
    well, 2 pencils actually.
    i just cut off tiny parts from those pencils and sharpenened them so that they would fit between be sound card and fan. :)
  24. Squishi
    Squishi n00b
    6
    Jun 25, 2009
    Needed to exhaust some of the hot air from my HD4870 card, so I slapped a 92mm fan in there. Works well, dropped ambient temps by about 7°C and dropped my GFX idle temps by 15°C. Under load it can still peak at about 80°C, but at least it isn't pushing 100°C anymore.
    [​IMG]
    [​IMG]
  25. T-BONE
    T-BONE Case Gawd
    717
    Jul 20, 2000
    LOL! I made a few of them Ghetto Mods in my life time...
    Whats up peeps. Long time no see!
  26. illuminate
    illuminate [H]ard|Gawd
    1,895
    Nov 24, 2007
    cooler is a bit too heavy for my 9600gt, and until i find something better:
    [​IMG]
    Yes, that's a screwdriver
  27. alan.p
    alan.p Limp Gawd
    409
    Apr 30, 2006
    So either with or without that prop, the card itself is screwed? :D
  28. illuminate
    1,895
    Nov 24, 2007
    in more ways than you can imagine ;)
  29. dandv
    dandv n00b
    20
    May 7, 2009
    Originally posted in the Show Your LCD(s) setups!!! thread, but CLock3 kindly pointed me to this one.
    So until I find a silent IPS sRGB 24" monitor with HDMI input that sells in the US for under $900, this is my setup:
    [​IMG]
    Specs:
    • Front support: 3x pineapple cans
    • Back support: 2x 1.89L apple juice bottles
    • bottom support: 2x Glide floss (ensures that sound from the front speaker isn't muffled by the desk)
    All supporting accessories available from Safeway. I've had this setup for a few months and it works surprisingly well.
  30. falconman
    falconman Limp Gawd
    489
    Dec 17, 2007
    actually looks comfortable.....
  31. socK
    socK 2[H]4U
    3,672
    Jan 25, 2004
    holy shit this thread
  32. Squishi
    Squishi n00b
    6
    Jun 25, 2009
    3 x 5.35inch drive bay covers, a bit of super strength glue, 1 x 120mm fan plus fanguard and 15 minutes with a dremel = ghetto fan mod.
    [​IMG]
    [​IMG]
    And pictured below is the old 550watt PSU I ripped the 120mm fan guard from.
    [​IMG]
  33. Pylon
    Pylon [H]ard|Gawd
    1,299
    Dec 28, 2008
    Well, here's my laptop as of now. The thing overheats with 70+ temps at load, and because I run folding@home on it it was unacceptable. It's used as a desktop, since the batteries don't hold a charge anymore. I was sick of it overheating so I removed the keyboard and stuck an old aluminum heatsink from a Duron 800 on the heatpipes. There's an old 120mm fan rigged to run off USB blowing air sideways. Now load temps are around 45C :D The other heatsink is for the graphics card.
    [​IMG]
  34. Emission
    Emission [H]ardness Supreme
    4,214
    Dec 6, 2005
    @Squishi, that fan mod looks damn good.
  35. Incomplete_Spork
    Incomplete_Spork [H]Lite
    73
    Jun 27, 2008
    Damn straight.
  36. Squishi
    Squishi n00b
    6
    Jun 25, 2009
    Thanks guys! I do try... :D
  37. OmegaAvenger
    OmegaAvenger 2[H]4U
    3,358
    Sep 25, 2007
    than fan mod is hardly ghetto. its too clean for that. It looks like how things were done before the pre-mod days.
    Ghetto is when I hacked my case so i could fit a car stereo in it and powered it of the computer's PSU.
    I wish I had pics.
  38. twofortyfreak
    twofortyfreak n00b
    5
    Jul 9, 2009
    My Arctic Cooling Freezer Pro 64 cpu fan died, so I decided to zip-tie a 80mm fan right through the heatsink. Actually does a decent job, but in the future I think i'll just mate a more powerful 80mm with the AC Freezer shroud and hook it up to a front panel fan controller, so I can manually control the fan speed instead of the motherboard.
    [​IMG]
    [​IMG]
  39. MiniFolder
    MiniFolder n00b
    15
    Jul 27, 2009
    here is a picture by picture of my custom GFX cooler using cheapo and spares, also the tape was 'permanently borrowed' from my old care home (stupid social workers!).
    an AMD CPU HS attached with origional 'Plustic' HS above:
    [​IMG]
    attached a CF on the front of card to blow extra air through HS:
    [​IMG]
    add an air channel for the ram chips allong the top:
    [​IMG]
    Final Product:
    [​IMG]
    Folds Brilliantly at 700Mhz (50*C) for a single GPU computer:cool::D!
    also looks half decent does'nt it:cool:?
    Just for kicks, my dads boss asked me to fix his 800Mhz P3, the previous repair technitian used an incomaptible USB card to 'speed things up', resault... you guessed it, the computer stalled half way throu booting. well after knowing the amount of abuse the computer sustained, i decided that i might as well use the cd drive as a cup holder (and there wasnt any room on the desk anyway):
    [​IMG]
    (of course... i know this is stupid to do:D)
