Endurance Man
- Aug 13, 2005
Do you honestly believe he punched the case and it folded in like that
, i call BS, but thats my opinion.
Endurance Man said:Do you honestly believe he punched the case and it folded in like that, i call BS, but thats my opinion.
ikellensbro said:My BFG 6800nu has a 2 fan heatsink (doesn't cool any better than nVidia's stock hsf) and one of the 40mm fans will start clicking every now and then because of dust or whatever. Usually a simple tap will get it running smoothly again, but last week I tapped it a little too hard and it broke. I tried usuing an 80mm fan pointing up toward the card while leaning on my hard drives, but that didn't make much difference and my card was running at 80*C and artifacting a ton in WOW (even after I took it back down to stock speeds, it would still artifact, stutter, or lock up in WOW). The solution? Use another 40mm fan (duh):
Two rubber bands are holding it on pretty well, and a couple crushed packing peanuts keep it from vibrating on the heatsink (the fan is also controlled by a rheobus, its inaudible at 7v compared to everything else).
Nice ghetto loop there Elysian, somehow I forgot to post mine here when I had it running 3 1/2 months ago, so here's the pics now
The 5 gallon reservoir.
???Heatercore with 2 92mm fans and a card board and duct tape (mainly duct tape) shroud.
How the pump (Eheim 1048) and heater core fit in the reservoir.
The loop in all its glory.
man, you dont need standoffs for the mobo, just unscrew the hex screws from the pci retention plate and the vid card won't touch the groundJustLong said:I recently put together a enw PC, I got everything but the case on time and couldn't wait to start setting it up. My favorite part is the wood to make sure HDD didn't short on the metal of the CD ROM. Also I used the brass standoffs to raise the mobo off the table enough to plug in the video card.
God_Of_Death said:forgot one of my old ti4600
I see you have a Thermaltake Volcano 9... that thing must be loudGod_Of_Death said:forgot one of my old ti4600
http://i2.photobucket.com/albums/y45/xeno_god_of_death/kos_mos/PANA0116.jpg
animosity said:We had a crap case in my friends basement, so we chunked it around some and then through some spare parts in it. It worked.... once.
God_Of_Death said:these are a few years old. ran this rig for almost a year.
do i win a cookie![]()
NerveGas said:...unfortunately, there wasn't a camera around. I was at a data center performing one night, pulling guts from a few machines and putting in others, and I had a SuperMicro board that wouldn't fit the 2U chassis I wanted it in - the redundant power supply had a little protrusion that kept the motherboard from fitting.
Well, I had to get that machine up and running. Looking at the offending corner of the motherboard, there were no traces that ran under it. If I could just take off that corner... but I had nothing with which to cut it. Finally, I decided there was no other way... I bit the corner off of the motherboard.
Yes, I bit it. And it took some work. Trying to take the corner off of a fiberglass sandwich isn't an easy thing. And it worked - I got all of the hardware in, and the machines back up and running well before business hours the next day.
2.7 foodstamps from me. I've done the same thing with a GF440mx and an intel 2.6c P4 heatsink, but I used dental floss instead of zip ties.wormester said:
