Possible to test a Mobo without case?
SpeedyVV
Greetings.
I got a new motherboard that has a 7 day DOA return policy.
Therefore I would like to test it without a case.
Yes, I do have a case, but I also dont feel like taking that case apart because it is my work system.
So I was wondering, if I dont plug in the Power and Reset and HDD cables to the mobo is there a way to start the mobo?
Yes, I do have CPU, Memory, PSU, HSF, and HDD.
Thanks for any advice.
Just use a screw driver to jump (or connect) the two power pins on the motherboard to start it up.
Danny, you serious?
You mean like just connect them for a second and then remove the screwdriver?
I'll give it a try. Thanks (I hope)
Not that I dont trust you, but it sounds so ghetto. ;)
It sounds funny but it's basically the underlining principle of what's happening when you press the power button. :)
Some info from my cut n paste...
/*------------- <cut n paste> -------------*/
If you have both the 20/24 pin main ATX connector plugged in, AND the 4-Pin ATX12V P4 CPU (OR 8-pin EPS) connector plugged in, then the board should boot fine.
Setup everything outside of the case, with the mobo on top of its cardboard box. Plug in only the essentials:
- PSU (namely: main 20/24-pin ATX connector and 4-pin ATX12V P4 CPU Connector (OR 8-pin EPS))
- CPU w/ HSF (don't forget to plug in the fan)
- Single stick of ram
- Videocard if there is no onboard video (and PCI-E power, if needed)
- Monitor
- Keyboard
- System speaker/buzzer (if no onboard one is present)
* Use a screwdriver if your board doesnt have an onboard power switch. Jump (connect) the two power switch leads to turn the power on (hold connected for a few seconds).
/*------------- </cut n paste> -------------*/
Thankis for all the help.
I am happy to report that I was able to "screw" the mobo On and Off over and over.
Yeah... I've used a screwdriver more than once.... I had a mobo one time that I could not tell what pins were for power... so I just kept rubbing the screwdriver up and down pins until I found the correct two! :)
I do think $15 for someone who builds a lot of systems is worth it.
But having said that here is the Test Bench with Windows Home Server being booted.
Pretty cool, Intel E4300, 2 Gigs Corsair ram, Keyboard, mouse, 4 Terabytes of HDDs and it only pulls 70Watts at the wall.
Being Booted:
Yeah it works:
Storage!!!
But if someone built a lot of systems, I'm sure they'll have some old cases lying around. If not, then they don't build enough systems to need the switches/LEDs, lol. :p
