What does "honest" mean in this context?
The build quality of that looks like $30.
I'm not a professional photographer. The pictures don't really tell the story.
The player is nicely built. I don't know what you're pointing out exactly? The skin is stainless steel, btw.
The sound is good, and that,I believe, is the point.![]()
Read the title as Porno Music. Am disappointed.
Wow, a kickstarter to buy an iPod that's bigger, heavyer, probably more expensive and has more limited selection.
I'd buy that for a dollar.
it ain't an iPod.
The music selection on the store beta site is pretty big, IMO.
Plus, I can put any of my CD quality mucic I own on the player.
Yeah. I backed it.
I like the player so far.
Now.....get off my lawn.
Nothing stops you from putting your own CD quality music to iPods either. I'm not sure about the format support though, mp3s are quite enough for any portable use for me anyway. The only difference being that iTunes has a huge selection of music available in addition to that.
lolJRiver
One of the keys to all this is the format for the music and even more important the Pono uses all discrete components as opposed to the AMP on a chip most products use and all discrete components in the analog stages, something rare in todays world.![]()
Before I comment, I will point out that I do not own this product, nor have I heard one.
Discrete amps and even DACs can be really, really good. However, IC-based DACs and amps (e.g. op. amps) can sound really good as well and have had MUCH more R&D put into them over the years than just this single product. Most likely relatively high quality ICs would do a better job. If someone I know were to, for whatever reason, bet me $20 that the amp section in the Pono distorts less than something like an AD8599, I would take that bet (I would be in favor of the AD8599 of course). But then again, I'd also take a bet on the side that it wouldn't actually be noticeable to the human ear. Only to high-end measuring gear.
Discrete amps are typically only used for marketing purposes.
I'm sure it sounds just fine and CSN[Y] is an amazing band (one of the best of all time) and I wouldn't mind having their signatures on stuff that I use. However this doesn't look all that pocketable and would be a deal-killer to me.
To OP and anyone else who has one, how do you feel about the buttons on the front? They look really lame to me and are probably why someone else previously said that the build quality looks poor. Do they feel as bad as they look (to me and that other guy at least) or are they fairly nice? How's the tactile feel on them? Hopefully they aren't mushy like a ZX Spectrum...
Southern Cross is a VERY strong contender for my favorite song of all time.
It's provided by an outfit caller JRiver.
Because the iPod is ... dishonest?I have compared the sound of the same music from my own stash on my old ipod and my pono.
The pono is better hands down.
JRiver makes pretty good software, though usually overly complex. Join their Interact forum (http://yabb.jriver.com/interact/index.php?board=41.0) and make a post about your problems. Usually some one is willing to help and sometimes you'll get the people who make the programs reply. I use their Media Center software as a front end for my HTPC and it replaced Winamp on my desktop and laptop.
That's helpful.![]()
Maybe I should have just said the iPod sounds like shit compared to the Pono?
It's pretty difficult to put into words because music and listening is very subjective and will often depend on the quality of equipment one has.
I think I have a pretty large music collection.....hundreds of CDs, nearly that much vinyl, and some digital.
I use a Yamaha receiver over Klipsch speakers most of the time, and when my wife lets me, I listen in the living room over my one prize, a pair of B&Ws that cost me an arm and a leg
I have a pair of AudioTechnique phones and a pair of Sennheiser phones.
I've got an iPod.
The Pono reproduces music as close to what I hear over my stereo. It plays the full spectrum with quite a good replication of the depth and fidelity the CD or vinyl means to produce.
The iPod can't and doesn't do that. The music feels like it's held back or strangled somehow. You just don't hear everything....but that's OK. An iPod is for portability and the library is vast.
I can take my iPod anywhere and abuse the shit out of it....the Pono not so much. But to me they have different uses.
What I like about the Pono is I can take it to my office and at the end of the day, when I'm finishing up and everyone else has gone home, I can listen to some great music, nearly as good as if I was sitting at home.
Sounds like your iPod is either broken or your headphones do not match it. Is it an older model? I noticed sound quality improvement when stepping up in iPhone models so maybe the older models are not that good.
I've got an iPod.
The whole country? What do you mean? Behind which other countries? How are you measuring this? As is usual for what?The US as usual is behind on High-resolution audio. The Pono is a good attempt to catch up and works well.
Considering the CDDA Nyquist limit is 22 KHz, I find it unlikely any 85 KHz acoustic distortions are finding their way into your room when you play a CD. Particularly considering no (traditional) mic will actually record anything of substance at that frequency, or even half that frequency.For some reason people still think the limits of the human ear justify compressed music but they forget all about a little thing called "Harmonics". The cool thing about records was their frequency response went out to 65 to 85k and as such they could capture the harmonics of music and the rooms and halls where the music was recorded. Now, while these harmonics went well beyond the range of our ears they have the cool ability to bounce around and return back to the audible range thus adding that little extra that you can hear on really good CD's
Mic and amp self-noise, buss noise and dither, though: those things make it into high-resolution recordings. If you really want that stuff bouncing around your room at entirely sub-audible levels, by all means, listen to high-resolution recordings. Otherwise, high-quality compressed formats are just fine.
LOL you aren't going to get 85kHz from a record. That's absolutely ridiculous. It's theoretically possible to reproduce higher frequencies in analog than CD since CD is pretty limited in range (and distortion gets fairly high as you approach 20kHz - only 2 sampling points at the maximum 22.05kHz is somewhat unacceptable - 2 sampling points could very well describe a sine wave, a square wave, a sawtooth wave, or just about anything else - it's just not good enough), but manufacturing tolerances will still not allow records to go anywhere NEAR 85kHz. And if they did, those bumps would be so small that they would wear down very quickly (maybe one of those laser-based turntables could manage the same job without the wear and tear the needle causes though). I'm all for an upper range of >20kHz because many humans including myself CAN hear up to at least 25kHz, but 85kHz from a record is just crazy. I do support the pretty-much-dead SACD over CD, though.
As soon as I learned some electronics (back in vocational school), I realized how crappy a standard CD is. Good thing that we can't hear distortion at 20kHz anywhere near as much as we can at lower frequencies that matter more (so it's not a HUGE deal). But SACD (and DVD-A and other high-res formats) are just better.
I will say that records can sound really good on the right setup when manufactured well. But it's hard to manufacture a record very well, and I wouldn't trust that any can actually go to 85kHz. Not saying that records are downright crap, but they are also not "all that."
'fraid not. Harmonics are distortion. It's just a particular kind of distortion of which there are many that may or may not be euphonically endearing. I have to assume that you agree with everything else I said, having taken issue only with a single word.Distortions? Where did I mention distortions? HARMONICS...quite a different thing.
The non-sine features you see on a scope are higher-frequency content, so that's not so. This is the entire point of band-limiting the input so that you record only up to 22KHz....only 2 sampling points at the maximum 22.05kHz is somewhat unacceptable - 2 sampling points could very well describe a sine wave, a square wave, a sawtooth wave, or just about anything else - it's just not good enough...
'fraid not. Harmonics are distortion. It's just a particular kind of distortion — of which there are many — that may or may not be euphonically endearing. I have to assume that you agree with everything else I said, having taken issue only with a single word.
I don't care what people listen to or how they listen to it, but I don't think people should try to sell others on something with dubious reasoning. Particularly when that line of reasoning isn't applicable in the current context.
