PLX PCIe Bridges
Zarathustra[H]
Extremely [H]
I've googled a bit but haven't found any good information about these.
What I know: They sit between the PCIe slots and the CPU/Northbridge and act sort of like an Ethernet switch for for your PCI.
In other words, all slots get full PCIe speeds regardless of how many lanes go to the CPU. They can communicate with each other at full speeds, and are only limited if they all need to communicate with the CPU at the same time.
This sounds really great.
How does it work in practice?
Does this chip have any performance issues? It must introduce some level of latency over a PCIe lane going straight to the CPU. Does this latency have any impact?
Are there any compatibility issues with any PCIe cards over a bridge like this?
Much obliged,
Matt
They are just like NF200, except better. Lower latency, lower power use. They are in turn more expensive, but I trust PLX a hell lot more than NVIDIA at making PCIe gear.
Are you aware of anyone who has done side by side comparisons - lets say - of native 16x-16x SLI/Crossfire vs. SLI/Crossfire sharing 16x lanes using a PLX chip?
you mean 8x-8x right?
The chip doesn't come into play in that configuration as a stock i7 has enough lanes.
Doesn't it come into play when you do 8x-8x-4x and you have other devices like a SATA controller, USB, network, etc using PCIe lanes.
To find out, we just need to find a comparison between ASUS P8Z68 DELUXE and ASUS P8Z68 Pro. The Deluxe has the chip, the Pro does not.
No, sorry. It would be kinda impractical as you would need near identical motherboards and setups.
