I hope this is the right forum to ask this, if not, could a mod please move it to the proper location.
I recently did a major upgrade to my computer, basically it's a new computer in the old case.
Components:
EVGA 640 8800GTS R
(x2 SLI Config)
MEM 2GB OCZ HIGH PERFOMANCE DDR2 (Purchased 4GB, RMAing one set due to a bad stick)
Motherboard VGA 122-CK-NF68-A1 N680i SLI R
PSU Thermaltake 700W
CPU INTEL E6600 2.4G 775
OS: Windows Vista Ultimate
-Latest drivers for everything.
-Latest Windows updates
-Latest BIOS, default settings
-No Overclocking or tweaking of anything
-Power set on seperate rails to the max extent possible
Now my problem:
While installing new software the computer pauses for long periods of time (up to several minutes or longer) and appears to be doing nothing, no HD activity. I can't seem to do anything during these pauses, although the mouse or computer doesn't completely lock up. I also sometimes get pauses when just starting software. Other times the computer just seems much slower than it should be. I've installed temperature monitoring software and temps are good. They are a little bit high, but well within spec on cpu and graphics cards. It's driving me nuts...Every time I use this computer it just doesn't seem "right"
Any help or suggestions would be greatly appreciated...It's driving me insane. If you need any more info just ask.
Thanks in advance.
Components:
EVGA 640 8800GTS R
(x2 SLI Config)
Now my problem:
Thanks in advance.
