Please help me select mobo and CPU for office comp
Chevy-SS
My office computer crapped out. I want to replace the mobo/CPU.
I have a HD already. It is a Maxtor 300GB DiamondMax 10 serial ATA. Here's the HD I plan on using:
I also have some RAM laying around, that I'd like to use, if possible. If I have to buy new RAM, no big deal. I only need one Gig. Here's a pic of the RAM I have on hand:
And finally, I'd like to re-use the existing case and power supply. Here's pics of the case, with the old mobo/CPU still in place:
So, I've got a case, power supply, HD and some RAM. Can someone recommend a cheap mobo and CPU combo (and RAM, if necessary) that would work with my existing parts? This is simply an office computer, used for surfing net and emails. Very basic components are all that's needed. I plan on re-using the legit Windows XP Home edition.
Many thanks for any help. This is the first time I have attempted a major repair like this.
I would probably build a whole new system using either an Intel G31 board with a E5200 (and then as much DDR2 memory as you need) or an AMD 780G board with whatever processor is in your budget (plus as much DDR2 memory as you need). The AMD is probably a little better performer with graphics. The Intel is probably better with raw processing power. Both should be around $125 or so depending on the memory you buy.
That memory is kind of old. I'd just sell it on ebay or in the FS/FT forum and get a couple bucks for it and go with DDR2. 2GB of DDR2 is maybe $25 or so.
The RAM you have now is DDR1, which will not work with any modern board. Unfortunately, you can't reuse it. The good thing is that DDR2 memory is very cheap though, so you'll be able to grab 2GB or 4GB for a very small price. Since you're trying to do this on the cheap, I suggest this 4GB kit: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227364
My second comment is regarding your PSU. It is very low-quality, and I wouldn't recommend that you keep it. I suggest you purchase the PSU listed in this thread instead (make sure to use the promo code during checkout to get an extra $12 off): http://www.hardforum.com/showthread.php?t=1397384
As for the CPU and mobo, I suggest these two components as a general recommendation:
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131350
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
If you go with all of these parts, your total cost will be just $181 after rebates, and you'll have a very nice machine that'll be able to handle whatever you need it to.
+1 to these suggestions. It's the right mix of quality, value and low prices.
I think an AMD combo would actually be better for an office comp because the graphics are somewhat better than the Intel IGP. The 780G graphics are far superior to the X3100. Not that the IGP is everything, but at least you can turn on some of the Windows eye candy in the future.
Well, he's using XP, so video quality is not a big concern. And the integrated GMA X3100 is plenty for Aero should he upgrade to Vista or Windows 7 in the future.
Call Dell for a business computer. Its worth it for the warrenty.
Actually, this is probably the best advice as you can get a business Vostro line for around $450 with a monitor and warranty.
Thanks very much for the suggestions. But I would only need entry-level CPU and RAM. 2GB of RAM will be way more than enough. Plus, a cheap CPU will be just fine.
Perhaps you could revise the CPU downwards and RAM to 2GB?
It's not that I'm a real cheapskate here. I have the money, no problem. I'm actually just testing myself out on this repair/build. If this doesn't work out, then I'd like to be able to throw it all in the trash without losing too much money.... :)
Many thanks to all, for help.
The RAM I picked out actually costs less than the cheapest 2GB kit Newegg is selling after the rebate is factored in. I originally had picked out a 2GB kit, but this ended up being cheaper so I figured I may as well. As for the CPU, you could go cheaper, but this is really the cheapest "good" CPU you can buy. The most you would save is maybe $20-30 on that part, and IMO it's really worth that extra little bit of money for the extra longevity you'll get out of that system (since you're coming from a Socket A PC, I figure you intend to keep this thing for a while).
If you're really set on getting a cheaper CPU though, this is what I would suggest: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116069
Even then, it's still only about $20 cheaper, and it's a much slower chip.
OK, good advice - many thanks..................... :)
AMD was definately the way to go for cheap good office cpu and mobo combo. I may have spent the extra 10 bucks for the dual core though.
Yeah, I probably would have done that also, but depending on what you're doing with office applications, you might never notice.
