Hello all,
I finally decided to build a new PC after 5 years of using a P4 system. I'm slowly catching up on all the new tech and products and this is what I have so far. Basically I just want to make sure I'm not gimping myself or buying overkill in one area. This PC will be mainly used for gaming on an existing 24" 1920x1200 monitor.
Motherboard - Gigabyte P55A-UD4P
http://www.amazon.com/Gigabyte-4DDR3-2200-CrossFireX-Motherboard-GA-P55A-UD4P/dp/B002XDQC40/ref=wl_it_dp_o?ie=UTF8&coliid=I2AQA7DIV7D5EO&colid=1DTHWHBSYKM8D
CPU - Core i7 860
http://www.amazon.com/Intel-Core-Processor-LGA1156-I7-860BOX/dp/B002KQ5KE8/ref=wl_it_dp_o?ie=UTF8&coliid=IBOZPSZE45PDF&colid=1DTHWHBSYKM8D
Memory - Corsair 4GB DDR3 Kit
http://www.amazon.com/Corsair-CMX4GX3M2A1600C9-XMS3-PC3-12800-Memory/dp/B002LE8D2A/ref=wl_it_dp_o?ie=UTF8&coliid=I3HVDBDTYG7OV0&colid=1DTHWHBSYKM8D
HD - WD Caviar Black 1 TB
http://www.amazon.com/Western-Digital-Caviar-Black-WD1001FALS/dp/B001C271MA/ref=wl_it_dp_o?ie=UTF8&coliid=I11WK9LQC9SZFA&colid=1DTHWHBSYKM8D
SSD - Intel X25-M 80 GB
http://www.amazon.com/Intel-Mainstream-Solid-Retail-SSDSA2MH080G2R5/dp/B002IJA1EG/ref=wl_it_dp_o?ie=UTF8&coliid=I21CI6WIO3G32A&colid=1DTHWHBSYKM8D
PSU - Corsair 750 Watt
http://www.amazon.com/Corsair-CMPSU-750TX-750-Watt-Certified-compatible/dp/B000X2677A/ref=wl_it_dp_o?ie=UTF8&coliid=IC4XSHDB2AEW5&colid=1DTHWHBSYKM8D
Video - XFX Radeon 5850
http://www.amazon.com/XFX-RADEON-5850-Express-HD585AZNFC/dp/B002Q4U5EY/ref=wl_it_dp_o?ie=UTF8&coliid=I3828BM46X8RPL&colid=1DTHWHBSYKM8D
The only thing I'm not sure about yet is what case and CPU cooler to get. I'm not that interested in overclocking, but if it's easy to do I wouldn't mind playing around with it.
Also, I'm not particularly attached to the various brands I linked above. These were just the easiest/first ones I could find on Amazon. For example, I'm not sure if the Corsair memory kit is the best or cheapest option out there right now.
Lastly, would that power supply be enough to handle a second video card in the future if I wanted to do Crossfire? I'm not planning on it but you never know.
CPU - Core i7 860
