Not much more to it really. I put in the memory and have it sitting in a rack at a local datacenter now.Nicee one.Thank you for the info.I wait for more when you finish it
Thank you for your input!Need to rotate the heatsinks so that the fans face all the same way. Hope you have some 6-core chips in that as something old like say 8347s are going to be slooow. Should get the M4985 riser board too.
Thought you guys would like to see my Asus KGPE-D16, only one processor at the moment though...
Chenbro SR10769, kicks ass. I have the 2 option hot-swap drive enclosures installed which are great.case ?
Dual 479. There are 2 fans in the system, but they throttle down a ton and aren't probably necessary. I'm still waiting on the memory and IPMI card to show up though. Here is a pic from the other side with the heatsinks on and the riser out:
Bought it new off eBay actually. I quite like it due to the lower power usage. Interested in one? It only has 2 ethernet ports though, but you can always add more through either the PCI-X or PCIe riser.May I ask where you pick that up? That would make a cool little box, it has 3 ethernet ports as well if I'm not mistaken.
I have the Supermicro one (this specifically). Prefer it over the Tyan one, but I guess both will get the job done. Mine is more aimed at 1U servers since I can use either PCI-X or PCIe (has a proprietary riser for both). I wouldn't pay $100 for just the board though.Oh I saw the mobo on Geeks.com with 1 100Mbit Intel and 2 1Gbit Intel ethernet ports. Yea, they look really cool. I'd love to make it into a PfSense box or something, it'd certainly be quieter than what I currently have running there.
looks good.
Got myself another dual processor system. This one is a bit different from the usual stuff you see around here. Being able to use 15w processors is pretty neat:
Supermicro 6014L-M. No idea on the current price as I don't think it is made anymore.what is the actual unit make and model ? Got a price ?
Yes, I still have it in colo. Everything is for sale given the right price.still have the unit ? it for sale ?
Yep, any of the 3.5" mount 1207 boards can use those heatsinks. I did that with my quad 1207 system back in 2008. Not possible on 4.1" mount 1207 boards though (there are 2 different heatsink sizes if you didn't know).For whoever said those plastic brackets were for something else oke: oke:
http://img96.imageshack.us/img96/7951/cimg3180.jpg
They DO convert 1207F mounts to a normal AM2/AM3 bracket. That's 4 AM3 CPU HSF right there...
Nope, the socket is considerably larger and has a new mount. Socket C32 reuses the same mounts as 1207 though if I'm not mistaken.oh my
I've been outclassed
But I'm happy
Does G34 use the same mounts?
C32 is 3.5"
G34 is 4.1"
Noctua does have a cooler coming out for G34 and C32 though: Noctua Not sure when it will be available though, I want two for my system.
jetfire,
why not just install a ati eyefinity?
