Liquid_Cooled
- Sep 28, 2004
the base of the Neo-Flex has a clamping device that you clamp down to the edge of the desk.
These are very nice LCD arms. I recently bought 2 for my 2-2005's. I highly recommend buying from YesMicro. I got mine for about $89 each. The arms were purchased and arrived all in about a weeks time as they appear to have warehouses all over the place with plenty stock on hand. ... Anyway... to answer your question, one of the features I really love about these new arms are the many mounting options. You can either do the standard "clamp" method where you slip the bracket over the back edge of your desk and clamp it down. Or you can use the option 2 where you remove the bracket and reattach another mount plate that locks the arm down using the "power cord hole" in the average office desk. .... Or you could even do what I did for 1 of them. I wanted my main screen to have a longer reach for when I am gaming and I can center it in front of me toward the edge of the desk. So I took a 1/4" drill bit and tapped a hole into my desk and locked it down that way. So I have my 1 Dell 2005 rotated in portrait mode for Text and web surfing mounted using the "clamp" method, and I have my main use gaming/ desktop screen in landscape mode mounted using the "hole in desk" (also called "grommet mount"). (I'll try to get some pics up later)yohan_nl said:Very nice combination. I have the Dell and I'm considering an ergotron neo-flex myself. What I wonder about is how the neo-flex stands by itself, I mean: do you need to connect it to the desk with screws or something? Or can it stand all by itself, even with the heavy screen completely forward?
...Thanks EnderW and Soul...soulsaver_8229 said:Useing those arms dosent viod warantee?
looking setup
soulsaver_8229
why would it?soulsaver_8229 said:Useing those arms dosent viod warantee?
looking setup
soulsaver_8229
Oh, I thought those were 2405's - they look big.Pringals said:...Thanks EnderW and Soul...
lmao to your sig ... "There are 3 kinds of people...." I am making note of that in my scrap book.
This may have been the end to my "Toy" buying for a while. I would love to get one of the 2405's and ebay one of the 2005's, but we have been house shoping for several months now and it looks like we will be making an offer on one here this week. I guess it's a good time to start garage sale'n for some better furniture.![]()
what arm(s) are you using?Tanquen said:http://briefcase.yahoo.com/tanquen2000
2405FPW X 2005FPW baby!
Oops, link should work now.
One more try.
EnderW said:what arm(s) are you using?
looks like they are just floating
Pringals said:These are very nice LCD arms. I recently bought 2 for my 2-2005's. I highly recommend buying from YesMicro. I got mine for about $89 each. The arms were purchased and arrived all in about a weeks time as they appear to have warehouses all over the place with plenty stock on hand. ... Anyway... to answer your question, one of the features I really love about these new arms are the many mounting options. You can either do the standard "clamp" method where you slip the bracket over the back edge of your desk and clamp it down. Or you can use the option 2 where you remove the bracket and reattach another mount plate that locks the arm down using the "power cord hole" in the average office desk. .... Or you could even do what I did for 1 of them. I wanted my main screen to have a longer reach for when I am gaming and I can center it in front of me toward the edge of the desk. So I took a 1/4" drill bit and tapped a hole into my desk and locked it down that way. So I have my 1 Dell 2005 rotated in portrait mode for Text and web surfing mounted using the "clamp" method, and I have my main use gaming/ desktop screen in landscape mode mounted using the "hole in desk" (also called "grommet mount"). (I'll try to get some pics up later)
All in all... these arms were just what the Doctor ordered and I am very satisfied with the product and the retailer, YesMicro.com.
wow thats super bad ass, looks very versitile.Tanquen said:Some asked to see the arm, here it be.
http://www.hardforum.com/showthread.php?p=1027882943#post1027882943
personally i would sandwich it with some rubber or something, the metal underpart of the clamp could break or scratch any glass or delacate surface i think. Also about it shaking, yes when i bump my desk or something with my chair it does do a little wobble but nothing to bad. One thing that ive notices which is kinda lame because of my corner desk is that the monitor is never directly in the center because i dont have the extenstion to get some of the perfect angles. The rotation device on this makes it a bit difficult to just swing a tad to the left or right without moving the entire display.tpizarro said:Does the neo-flex arm seem pretty safe for a glass desk or should I sandwich the glass with something prior to installing the arm?
My two don't wobble at all ... but then again, I have the 2005's. The 2405's are a bit heavier and may be close to the weight limit on these arms.EnderW said:is it normal for the monitor to shake when I knock on the desk?
This one doesnt work? I even tried it on a different PC, seemed ok.
Just wanted to try my yahoo file sharing but I guess I'll try www.supload.com.
OK
