nobody_here said:wow, already the haters come out of the woodwork
I think Mr. Zalman needs to get movin' on some big copper cooling goodness for the G80 GPU's.mike686 said:Well, everything's fine now. I guess it was a false alarm. However, I can tell you guys that this thing gets up to 80 degrees celcius in a well ventilated case.
Water.Brahmzy said:I think Mr. Zalman needs to get movin' on some big copper cooling goodness for the G80 GPU's.
drdeutsch said:Here's his screenshot from his Fear Benchmark.
His comments:
Fear 1600x1200 all in game setttings maxed out with soft shadows enabled.
http://s2.supload.com/thumbs/default/fear1600x1_b7c75e2203a3dca51.jpg
Apoxi said:ok i'm sorry that you would consider me a "hater" but to be totally honest...when some new great card comes out...and you spend ~700 bucks for it, when you put that in your PC if it doesn't blow you away...then wtf is it worth? like when Chevy upgraded the corvette from LT1 engine to LS1....what is it worth spending the extra money if you aren't gonna be blown away? i don't hate nvidia, i've always been an nvidia fan boy, but lately they just keep throwing out mediocre cards and it's just not giving me a good reason to upgrade to them just yet.
revenant said:and vsync?.![]()
Brahmzy said:I guarantee you new drivers will make a difference. This thing's in it's infancy.
Siconik said:Hey Mike,
There should be two CMAA 16xAA settings, one with 4 and other with 8 z/s samples. Looks like you are using the 8x setting - can you run the test with 4 z? Also, could you run Shadermark?![]()
Jodiuh said:Craziness Mike. Thanks for all the infos. Would it be possible to compare the fan noise to some other cards/fans?
Jodiuh said:Ah thanks. 78GT had that loud little cooler, right?
mike686 said:Honestly I can't really say, since my case has 5 fans in it, so the noise kind of blends together.
mike686 said:I don't see anything of that nature. This is what my control panel looks like: (drivers that came on the CD)
D!Z said:you have 5 fans and your card is hitting 80?, what kinda case, just curious
Siconik said:Sorry, forgot this part: N(ormal) = 4Z/S; Q(ality) = 8Z/S... So, 16xN takes 4 Z/s samples (like 4xMSAA) but does 16xAA on the edges, while 16x8 takes 8 z/s samples.
DontMakeMeEatYou said:What PSU are you using?
tims880 said:Dude you got your 15 minutes of fame!
mike686 said:I still don't get what settings you want me to select. I am a n00b.![]()
tims880 said:So what do you think of the card? When I went from a 6800 ultra to the 7900 gt I was impressed. Do you feel the same coming from the 7800?
mike686 said:This one's for you sillyeagle:
FEAR, 1600x1200, 4xAA, 16xAF, all settings maxed except soft shadows.
Not much different than having soft shadows on, is it?![]()
Siconik said:LOL, I am not exactly explaining this cleary... F.E.A.R, 1600x1200, everything maxed out, 16AF 16N AA. Also, if you could run Shadermark, that would be great.![]()
