Perc 5/i Question about PCIe slots
Yeah man.
I had mine in my 2nd Pci-e 16x slot. Mine seems different since it doesnt have the ram slot on it or the bbu option.
It took a bit of mucking around on the my BIOS since I already had an onboard SAS controller as well as the Intel ICH10r. Some people need to cover a specific pin on the pci-e connector to get it to work.
Can you use the Perc5 in a x16 slot? the motherboard I am looking to use only has one x16 slot and 2 x1 slots. Are there are problems with doing this? you just insert the card all the way forward correct?
Yes, as long as it's compatible with your motherboard. Not all motherboards are cool with Perc5 cards for some reason.
how do you know?
you mean it may not work?
Yeah, there's a chance that it might not work
Is it just the intel chipsets it does not work with?
this is the board I plan to use. http://www.newegg.com/Product/Product.aspx?Item=N82E16813131325
Not exactly. Some Intel motherboards work just fine with the Dell Perc 5/i. It's a very odd thing: Even motherboards with the same chipset may have differ in compatibility with the Dell Perc 5/i.
Can't say if that AMD mobo will or not will not work with the Perc 5/i. Might want to hit up this thread:
Dell Perc 5/i - Mainboard Compatibility List
do you just need to mod it if it does not work?
If it's an Intel mobo, you just gotta put electrical tape over a specific set of pins in order to get compatibility. Not sure about AMD motherboards.
Thats just weird, first I heard of this. Does the PERC 6i do this too?
