Peer Review
tonytnnt
So I've got a friend building a system. I've looked it over a bit and made suggestions, but I'd like a peer review as well.
Old System:
Intel Q6700
MSI P6N Platinum Motherboard
4GB of RAM
Radeon 5770
Cooler Master 1000W PSU
other stuff
Gaming (Including Bad Company 2, Battlefield 3, World of Tanks), Web Browsing
$600-$700
3) Where do you live?
Omaha, NE -- No good brick and mortar places within 100 miles. I have Amazon Prime.
CPU, Motherboard, RAM, Hard Drive, Case, DVD Burner,
MSI R5770 Hawk Radeon HD 5770 1GB and COOLER MASTER Real Power Pro1000 RS-A00-EMBA 1000W
6) Will you be overclocking?
Unlikely
22" Samsung 1680x1050 (already have)
Within the next week or two.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
USB3 and SATA6
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Already have Windows 7 64-bit
His current list of parts to buy:
$325 - Intel Core i5-2500K and MSI P67A-G43 (This combo ends up being only $5 more than the non-K and gives him the option of overclocking in the future.)
$76 - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (He liked this more than the $3 cheaper set because it had better reviews.)
$50 - Samsung F3 1 TB
$20 - Asus DVD Burner
$90 - LIAN LI PC-7B plus II
Subtotal: $560.94
Shipping: $17.62
Total: $578.64
He's planning on replacing the 5770 in the next year or whenever it becomes a significant bottleneck.
Anyways, let me know if you see any issues with this or have suggestions. He'd love for it to be under budget, but can go up to $700 if need be.
Looks good to me.
The only concern I could think of is whether or not the PC-7B's two 120mm fans will be enough for the hot Arizona summers. (Though cheaper cases exist, I figured that your friend -- or you -- preferred the "cleaner" look of the Lian Li. As a former owner, I did.)
Yeah he currently has a Thermaltake Xaser II 6000 from forever ago. I think at one point he said he was embarrassed by it since it's in his living room, and he wants something a little sleeker. Also, he lives in Nebraska, which gets hot, but not Arizona hot. It'll be in an air conditioned room anyways, so ambient temp shouldn't be a major issue.
