PCP&C 750 $79 AR FS
Killer deal... smoking hot. This is an excellent PSU. I bought a black one for $90 AR just a few weeks ago.
this the one with the single 60 amp 12v rail. $115 then a $35 rebate. decent psu for the bread.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703019&Tpk=17-703-019
That is Officially Just Plain Wrong....considering that PCP&C's Silencer 500W PSU (only two-thirds the power and also single-rail) is mormally more than that. However, it seems that almost every PCP&C poewr supply got Marked Down.
ITEM: PCP&C Turbo-Cool 1kW-SR: Was:$499.99 Now: $199.99 (no rebate!)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703003
(Note: This is *less* than the TC-860:http://www.newegg.com/Product/Product.aspx?Item=N82E16817703013)
Excellent deal. @the post above, they're putting the two most popular PSU's on sale rather than the oddballs
Actually, the 1KW-SR is no longer an active sku. It's the 860 and the 1200 that are still active. So if you want the Turbo-cool 1000w grab it quick because I doubt they will be hanging around long.
do you think the name is long enough?
BFG Tech ES SERIES ES-800 800W Continuous @ 40°C ATX12V 2.3 / EPS12V 2.92 SLI NVIDIA SLI Certified GTX 260 NVIDIA HYBRID SLI 9800 GX2 CrossFire Ready 80 PLUS Certified Active PFC SLI Power Supply - Retail
as opposed to
BFG Tech ES SERIES ES-800 800W Continuous @ 40°C ATX12V 2.3 / EPS12V 2.92 SLI NVIDIA SLI Certified GTX 260 NVIDIA HYBRID SLI 9800 GX2 CrossFire Ready 80 PLUS Certified Active PFC SLI Power Supply - OEM
not exactly sure, and i dont feel like looking it up, but this may the psu that the front page here gave a crappy review.
looks like ocz is getting all the pcp&c models out of the warehouse in prep for the new ocz/pcp&c models.
Both of those are great freaking deals. I should wait till I sell my 500W Antec NeoHE before I bite though.
Once you've owned a PC P&C's "Silencer" series psu, you won't get any other brand. They are truely quite. :)
Yes, but so are other PSUs.
I own a 610W silencer btw...it does what I need, but it's not like I'm swearing off all other brands.
It's 'quiet' by the way
Which makes that price all the more remarkable (remember, it's less than the TC-860).
Like all current-model PCP&C power supplies, it's single-rail and non-modular (one reason why some sites give it bad reviews is because it's not modular); however, that price makes it the lowest-priced 800W or above power supply available from the Egg..
There are only two reasons I would pass on this deal (if I had the money):
1. It's overkill (that it certainly is; it's beefy enough to jump-start the Space Shuttle).
2. I absolutely needed a modular power supply (The only reason THAT would be the case would be if I were so into flash that I didn't do my homework regarding cable management and the impact on airflow; that's what tiebacks are for.)
Way to paint a broad, stereotypical brush. So modular equal rice to you is that it? Maybe you want to keep those stereotypes to yourself when so many people on [H] are on modular PSUs.
I got the PC P\C 860 for 200 after live cash back from buy...it was 264...
Would this power a i7 920 and 2x 4850s?
Edit: Snagged the 800w BFG. Awesome deal, thanks guys.
nothing wrong with a beefy single rail and modular adds failure points. cable management isn't that hard to learn.
I have made absolutely no secret of my outright *scorn* for modular power supplies (and, in fact, have explained why), and rank modular power supplies with multi-rail power supplies among my Most Loathed Trends in PC Hardware (I've no love whatever for multi-rail power supplies, either).
So, yeah; modularity in a PSU *does* strike me personally as more *flash* than anything else, especially considering that (according to most of those that have specified a modular power supply) the overriding reason was *aesthetics*. (Not airflow-management.)
Obviously you have not been following earlier posts (by me or anyone else) on these two (closely-related) subjects in the General Hardware forum, as to exactly why I give short shrift to both multi-rail *and* modular power supplies, despite their popularity and trendiness.
Modular units aren't an issue. I can count on one hand the number of modular units I have seen fail due to the modular cabling as opposed to the actual unit itself. The resistance added is inconsequential and the spec is to be checked at the end of the cable anyway....so the voltage drop is already factored into the units voltage regulation requirements. Beyond that, modular units are used in actual mission critical apps as well as consumer units:
The single vs. multi rail issue is nothing more than FUD.
I've always wondered about that. Thanks for saying that.
FWIW, I picked up a BFG ES-800 for $70 after MIR (link above)
It'll bring relief to my poor Antec NeoHE 500W that is currently pulling 515W from the wall :eek:
My problem with multi-rail PSUs is more a design and balancing issue; especially in terms of load-balancing.
Typically the most power-hungry *single* item in any PC (350W or more) is the graphics subsystem (especially discrete graphics); however, the problem is that it takes several drives (both hard and optical) to counterbalance the amperage draw of a single DX9c graphics card (I'm not talking anything major, but something on the order of nVidia's GeForce 6 series or ATI's X1K series); with newer products, the amount of counterbalance required only goes up! When a GPU can draw as much amperage by itself as most of the rest of the system put together, especially when, except at the high end, most multi-rail PSUs don't have enough amperage across *any* single rail to drive the GPU, balancing amperage draw for a GPU without buying too much power supply is difficult to *impossible* with a traidionally-designed multi-rail PSU for the same reason that calculating load-balancing across a series-parallel circuits is a real pain in the rear (a multi-rail PSU does exactly that; create MULTIPLE series-parallel circuits within a computer); as much as you would WISH to have current draws be additive across a multi-rail power supply, they simply do not. Worse; unused amperage (say you have only 5A of draw, or less, across a PSU rail rated for 20A; this is *commonplace* with multi-rail PSUs) winds up being wasted (usually as heat) which is energy-INefficient. This is why I am generally against overbuying power supplies, regardless of how many rails they have (or claim to). As someone with a vocational background (I took electronics in high school *after* discovering the wonderful world of mainframe computers), I found out the hard way that series-parallel circuits are a monster in design and implementation; considering that a multi-rail power supply does exactly that, why would I willingly *increase* my headaches by stepping back into that stew as opposed to the KISS design efficiencies of the still-available single-rail power supply?
1) There is no need for "load balancing". Each OCP circuit will allow X amount of current to flow until its cap is met. After that the combined amount of current is allowed to flow over all rails until the units total OCP cap is met. The amount of current being drawn on one rail has nothing to do with the amount of current being drawn on another rail other than to remove that amount of current from the total free capacity....just like with a single rail unit.
2) Trapped power does not exist. That is simply marketing BS. Don't believe me, you do the math.
Assume this unit really has its OCP set and that this unit has a total capacity of 64A on the 12v rails. There are 6 rails with 20A each on an 800w power supply. Find the trapped power.
3) This
DOES NOT OCCUR. An SMPS only delivers the current that is actually needed at any given time. If an item draws 5A then 5A is delivered there is not 15A being wasted as heat.
I am sorry, but none of those ideas you presented is true let alone a valid point.
3) This
So, you are implying that all the multi-rail PSUs are actually *single-rail* PSUs (in short, the multi-rail architecture is actually virtual)?
If so, I really have to ask; why go to that sort of trouble?
That is indeed what you are implying (that all multi-rail power supplies are actually single-rail power supplies in disguise). The question then begs *why*?
I never said or implied all multi-12v rail SMPS are physical single 12v source units. There are a number of different topologies on the market. For those that are single 12v sources everything I said above holds true. For those that are multi 12v sources, everything I said above holds true.
Still, the question begs (and it's one that nobody has answered to my satisfaction): Why multi-rail in the first place?
It's not as if single-rail is more expensive (while PC Power and Cooling is the best-known manufacturer of exclusively-single-rail power supplies, they aren't the only one, and aren't even the most expensive); in fact, with the recent price cuts, in most cases, PCP&C is among the least expensive in their wattage group, single-rail or multi-rail.
There has to be a justification for multi-rail (and the added complexity); so far, in my humble opinion, I have NOT seen it.
I'm (as you doubtless have noticed) VERY much a fan of KISS (Keep It Simple, Son!) when it comes to computer power supplies (minimum frills OR frippery). Multi-rail power supplies (all of them) add additional complexity. Additional complexity (to me) MUST be justified (I'm just as harsh when it comes to motherboards; the onboard CSA gigabit Ethernet on my P4C800-E Deluxe had to prove itself before I decided to buy it, considering I paid nearly three Benjamins for the mobo new).
Given that, why do you have YOUR preference for multi-rail (vs. single-rail) power supplies of the same capacity? (I can understand price being an issue; if that's the case, don't be afraid to say so.)
This has been answered a million times. The UL had a 240VA restriction that was also part of the ATX12v specification. This was for a number of reasons. The EPS specification also contained this requirement and the principle helps isolate high draw items from one another.
1) A single rail is on average cheaper to make given the fewer parts.
2) PC Power & Cooling doesn't manufacture ANYTHING Seasonic and Win-tact do.
3) PC Power & Cooling price cuts are because PC Power & Cooling is being distributed by OCZ now.
Um, well its been out there since the ATX12v2.0 specification came out a few years ago.
Ok, but they don't though. An OCP circuit is already in place.
You have no idea what my preferences are on anything.
My only preference here is that YOU not continue to repeat PC Power's dubious marketing page as fact.
yea ok well now tha the debate seems to be slowing down, the 750 is not $79 anymore, but you can still get it for $99 ar from newegg, which is still an ok price, no matter how many rails it does or doesnt have. (my zalman 1 kay dubba u has 6)
